Manufacture | Part Number | Name/Description | Software Version | Special Notes |
Calandra Racing Concepts | CRC4000 | Advanced Electronics Black Diamond LV | 2.1 software or higher | Has a blinking blue light when the throttle is in neutral and when set to the no-timing profile #1 |
Calandra Racing Concepts | CRC4002 | Advanced Black Diamond | 2.1 software or higher | Has a blinking blue light when the throttle is in neutral and when set to the no-timing profile #1 |
Castle Creations | | Mamba Max Pro | V1.26 | |
Graupner GmbH & Co. | GM-Genius 120 | Yellow, Red, and Green blink fast and at the same time in neutral position when the zero mode is active | V13.0 | Users must use Mode 0-5 after factory reset or after delivery. Modes 6-9 have high speed timing, no LED blinking. No high speed timing is allowed to set with PC-software. Mode 2 is factory setting. If high speed timing, no LED blinking. |
Graupner GmbH & Co. | GM-Genius 150 | Yellow, Red, and Green blink fast and at the same time in neutral position when the zero mode is active | V13.0 | Users must use Mode 0-5 after factory reset or after delivery. Modes 6-9 have high speed timing, no LED blinking. No high speed timing is allowed to set with PC-software. Mode 2 is factory setting. If high speed timing, no LED blinking. |
Graupner GmbH & Co. | GM-Genius 75 | Yellow, Red, and Green blink fast and at the same time in neutral position when the zero mode is active | Software Version V13.0 | Users must use Mode 0-5 after factory reset or after delivery. Modes 6-9 have high speed timing, no LED blinking. No high speed timing is allowed to set with PC-software. Mode 2 is factory setting. If high speed timing, no LED blinking. |
Graupner GmbH & Co. | GM-Genius 90 | Yellow, Red, and Green blink fast and at the same time in neutral position when the zero mode is active | V13.0 | Users must use Mode 0-5 after factory reset or after delivery. Modes 6-9 have high speed timing, no LED blinking. No high speed timing is allowed to set with PC-software. Mode 2 is factory setting. If high speed timing, no LED blinking. |
Hobbico | DTXM1300 | Duratrax DE10 Brushless Programable ESC | | A blinking green LED will be displayed when the ESC is at 0 (zero) degrees of timing and the throttle is at neutral. Also, if the ESC is at any advancement in timing the LED will be solid green |
Hobbywing | 81020000(blue) or 81020011(black) | Justock Club SPEC | N/A | Zero timing and non-adjustable |
Hobbywing | 81020010(blue) or 81020011(black) | Xtreme Stock | 508 | Zero timing – the RED LED Flashes when the ESC is active and throttle in neutral position. |
Hobbywing | 81020050 | Xerun 60A-SD V2.1 (Blue) | 508 | Zero timing – the RED LED Flashes when the ESC is active and throttle in neutral position. |
Hobbywing | 81020170 | Xerun 120A-SD V2.1 (Blue) | 508 | Zero timing – the RED LED Flashes when the ESC is active and throttle in neutral position. |
Hobbywing | 81020211 | Xerun 120A-1S (Blue) | 508 | Zero timing – the RED LED Flashes when the ESC is active and throttle in neutral position. |
KO Propo | 40051 | VFS-1 BMC Ver 1.5 | Contact Mfg for Firmware Upgrade | Must use zero timing and zero Advanced Profile signified by blinking LED on switch. |
Losi | LOSB9500 | 1/10th Xcelorin Brushless ESC | 01.01.30 | Must use zero timing and zero Advanced Profile signified by blinking color LED |
LRP | LRP80100 | Ai Brushless Reverse | N/A | |
LRP | LRP80150 | Ai Brushless Pro Reverse | N/A | |
LRP | LRP80400 | SPX Brushless Super Reverse | N/A | |
LRP | LRP80410 | Crawler ESC | N/A | |
LRP | LRP80500 | Sphere Brushless ESC | N/A | |
LRP | LRP80705 SPX Zero | Non – Updateable Zero timing when in profile 0 and Red LED is flashing | | |
LRP | LRP809050 | LRP SXX “Version 2″ Competirion Brushless ESC | N/A | Must use zero timing and zero Advanced Profile signified by blinking blue LED when in neutral. |
LRP | LRP809055 | LRP SXX : | | Must use zero timing and zero Advanced Profile signified by blinking blue LED when in neutral. |
LRP | LRP80910 | SXX Stock Spec Brushless | N/A | Must use zero timing and zero Advanced Profile signified by blinking blue LED when in neutral. |
LRP | LRP80915 | SXX Stock Spec V2 | | Desc: For Spec zero timing mode, both mode 2 (torque) and mode 3(timing) must be set to zero. Blue LED will blink in neutral |
Novak | NOV1709 | GTB 2 Sportsman Racing Brushless ESC | | Desc: When all timing is OFF, then white LED will be OFF to indicate no timing active. |
Novak | NOV1710 | Novak GTB | N/A | |
Novak | NOV1711 | Novak GTB Spectrum | N/A | |
Novak | NOV1712 | Novak Slyder Drift | N/A | |
Novak | NOV1731 | Novak Havoc 1 Cell | N/A | |
Novak | NOV1732 | Novak Havoc Sport | N/A | |
Novak | NOV1733 | Havoc 3S Brushless ESC | | (this ESC can be run on 2S or 3S) No timing built into ESC |
Novak | NOV1735 | Novak Havoc Pro | N/A | |
Novak | NOV1740 | Kinetic Racing Brushless ESC | Version 1.0 software or higher | ESC must be set at Timing Level = 1 or Zero Timing (default) |
Novak | NOV1741 | Kinetic 1S Racing Brushless ESC | Version 1.0 software or higher | ESC must be set at Timing Level = 1 or Zero Timing (default) **Note, this ESC will be shipping in August 2010 |
Novak | NOV1745 | Havoc Pro SC Brushless ESC | Version 1.0 software or higher | ESC must be set at Timing Level = 1 or Zero Timing (default) |
Speed Passion | Cirtix Stock Club Race # 12280 | No Timing adjustments-no LED | Non-Programable | |
Speed Passion | EXT98802LPF | GT-LPF 2.0 ESC (Carbon, Silver or Blue Version) | 508 | Must use zero timing and zero Advanced Profile signified by blinking LED |
Speed Passion | EXT98802LPF | LPF 2.1 ESC (Carbon, Silver, Blue) | V508 | Must use zero timing and zero Advanced Profile signified by blinking LED |
Speed Passion | EXT98802Pro | GT-Pro 2.0 ESC (Carbon, Silver or Blue Version) | 508 | Must use zero timing and zero Advanced Profile signified by blinking LED |
Speed Passion | EXT98802PRO | PRO 2.1 ESC (Carbon,Silver,Clue) | V508 | Must use zero timing and zero Advanced Profile signified by blinking LED |
Tekin | TT1152 | Tekin RS ESC | 212 ** NOTE NEW SOFTWARE PROFILE** | SPEC – Non Timing Mode is displayed by LED 3&5 blinking when armed and in neutral position. AVAILABLE 10/20/2010 |
Tekin | TT1153 | Tekin RS Pro | 212 ** NOTE: NEW SOFTWARE PROFILE | SPEC – Non Timing Mode is displayed by LED 3&5 blinking when armed and in neutral position. AVAILABLE 10/20/2010 |
Viper RC Solutions | VTX10 | #6VSVT10001 Sensored BL ESC w/ProGauge | A19 | Non timing indicated by GREEN blinking status LED next to letter “S” on V-port switch housing. In Race Modufied/Timing run modes the “S” LED will be off. |
Viper RC Solutions | VTX10-Lite | #6VSVT10002 Sensored BL ESC w/o ProGauge | A19 | Non timing indicated by GREEN blinking status LED next to letter “S” on V-port switch housing. In Race Modufied/Timing run modes the “S” LED will be off. |
Viper RC Solutions | VTX10R | #6VSVT10R01 Sensored BL ESC w/ProGauge | A19 | Non timing indicated by GREEN blinking status LED next to letter “S” on V-port switch housing. In Race Modufied/Timing run modes the “S” LED will be off. |
Viper RC Solutions | VTX10R-Lite | #6VSVT10R02 Sensored BL ESC w/o ProGauge | A19 | Non timing indicated by GREEN blinking status LED next to letter “S” on V-port switch housing. In Race Modufied/Timing run modes the “S” LED will be off. |
