中阳 新款4 bolt 引擎 CY 4 bolt engines F230 New Version Engine: 1) 4-Bolts Crankcase 2) 4-Bolts Cylinder 3) New Piston 4) Powerful Clutch Spring 5) Lighter Clutch Shoes 6) Big Muffler 7) Star shape bolts F – 230 Specification Model (2 Cycle Gasoline Engine) F-230 (New) R-230 Cooling Type Air Cooled Displacement cc 22.5 Bore mm 32 Stroke mm 28 Max. Power PS / rpm 2.5/ 13,500 2 Two Bolt 23 2.2 / 11500 Max. Torque kg-m / rpm 0.154 / 10,000 Two Bolt 23 0.145 / 9500 Min. Fuel Consumption g/PS . H 500 Two Bolt 23 550 Max. rpm at no load rpm Compression Ratio 9.5 Two Bolt 23 9.2 Fuel Recommend Pre-mixed (25 Gasoline : 1 Engine Oil) Oil Recommend FC grade 2 Cycle engine oil Ignition Type TDI Carburetor WT-668 Spark Plug Std. NGK: CMR7H Starter Recoil In rpm 8,000 5900 Clutch Stall rpm 10,500 Two Bolt 23 8000 Length mm 158 Two Bolt 23 168 Overall Size Width mm 240 Two Bolt 23 150 Height 199 Two Bolt 23 197 Weight kg. 2.24 Two Bolt 23 2.56 F270 F – 270 Specification Model (2 Cycle Gasoline Engine) F-270 Cooling Type Air Cooled Displacement cc 27cc Bore mm 35 x 28mm Stroke Max. Power PS / rpm Unknown Max. Torque kg-m Unknown Min. Fuel Consumption g/PS . H 500 Two Bolt 23 550 Fuel Recommend Pre-mixed (25 Gasoline : 1 Engine Oil) Oil Recommend FC grade 2 Cycle engine oil Ignition Type TDI Carburetor WT-668 Spark Plug Std. NGK: CMR7H Starter Recoil In rpm Unknown Clutch Stall rpm 10,500 Two Bolt 23 8000 Length mm 158 Two Bolt 23 168 Overall Size Width mm 240 Two Bolt 23 150 Height 199 Two Bolt 23 197 Weight kg. 2.24 Two Bolt 23 2.56 |
