ylovelq 长老 Fans 发消息
发表于 10-11-30 00:53:21 |显示全部楼层 来自: 中国云南昆明
DDM "FAST" Pipe vs. CPI Pipe - Similarities Explained
This has already been briefly discussed on the forum, but I would just like to make a new thread clearly outlining this issue so as to put all confusion to rest.
The DDM "Fast" Pipe and CPI Racing pipe have obvious similarities in shape. This, no doubt, leads one to ask the question "who copied who"?
Here is a brief history of this pipe. It all started with FAST, who had seen HEMISTORM's original idea, and approached us with an idea to make a pipe with a tip similar to that of a Pagani Zonda. We thought it was a great idea, and went to work on different designs. Our pipe designers worked some with Mike @ CPI (CPI is located less than an hour's drive from DDM). As a result, the DDM "Fast" pipe was developed, and Mike @ CPI changed the design significantly for his version (the CPI Pipe).
So, in reality, neither pipe is a "copy". They both share the same origins, with DDM going one way with it and CPI going another. DDM's pipe is a bit larger (wider), the CPI is more compact. Obviously the exhaust tip is the biggest difference.
Hopefully this answers the question clearly and concisely. When the issue comes up again (as no doubt people new to the forum will post the question) they can be referred to this thread to have their questions answered.
There is no bad blood between DDM, CPI, LargeScale RC, or FAST. We can all get along together to offer customers as many products as possible, and in the end hopefully we can all be winners.
Thanks for your support everybody. I hope this clears up any lingering questions.
-Dave @ DDM
这个就不用我再解释了吧。。。。。。。。
ylovelq 长老 Fans 发消息
发表于 10-11-30 00:55:07 |显示全部楼层 来自: 中国云南昆明
当然如果你能看得懂的话是最好了。。。。。。。。。这个是DDM老板DAVE发的帖子!!!!!!!
SonicRc 终极 Fans 发消息
发表于 10-11-30 01:01:15 |显示全部楼层 来自: 中国江苏苏州
ylovelq 发表于 10-11-30 00:55
呵呵,Dave 7年前来过中国,他说他喜欢这里
我说好下次来要Treat他的,他人很Nice也很喜欢中国的,哈哈
ylovelq 长老 Fans 发消息
发表于 10-11-30 01:03:01 |显示全部楼层 来自: 中国云南昆明
是啊,你和他那么熟了,他都没有完全告诉你这个区别,哎。。。。。。。。。
SonicRc 终极 Fans 发消息
发表于 10-11-30 01:10:37 |显示全部楼层 来自: 中国江苏苏州
ylovelq 发表于 10-11-30 01:03
呵呵,我并不care Fast和CPI得区别
想玩了弄一根试试就可以了,毕竟自己试过才是最真的感受
别人的观点仅供参考,RC是一个享受的过程,别较真儿
睡觉去了
hum16888 论坛元老 发消息
发表于 10-11-30 07:38:03 |显示全部楼层 来自: 中国黑龙江大庆
学习了·······
孤海独酌 超级元老 发消息
发表于 10-11-30 08:16:44 |显示全部楼层 来自: 中国广东佛山
学习了。。。
ylovelq 长老 Fans 发消息
发表于 10-11-30 11:28:26 |显示全部楼层 来自: 中国云南昆明
25# SonicRc
以后自己都拿不准的东西就别装大佬了吧,免得自己收不了场还要继续装淡定。。。。。
huanzhonghua 论坛元老 发消息
发表于 10-12-1 13:14:19 |显示全部楼层 来自: 中国江苏无锡
自己一个人玩的溜不叫溜要带动一群人一起溜那才叫牛!支持楼主的精神!!!
ylovelq 长老 Fans 发消息
发表于 10-12-1 13:47:30 |显示全部楼层 来自: 中国云南昆明
29# huanzhonghua
谢谢我会继续把自己学到的和大家分享
