本帖最后由 yst 于 10-11-14 22:37 编辑 1. PARAGON GROUND EFFECTS(黑瓶) This product is used for foam tires on carpet and asphalt tracks. Specifically formulated to give the racer ultimate tire traction. 海绵胎用,地毯或者沥青路面 2. PARAGON FXII(白瓶) This is Paragon FX II Tire Traction Compound. You apply this fluid to your tires before a race - it softens the rubber to provide you with the maximum possible traction. You can use it on carpet, Asphalt, Concrete, and even dirt ovals. Paragon FX-II tire traction compound is similar to Paragon's Ground Effects product except that it has more bite and less odor. 橡胶胎用,比赛前涂上,软化橡胶胎增强抓地力,可用于地毯,沥青,水泥路,甚至越野路面。气味比黑瓶小。 3. PARAGON TRACTION ACTION Paragon Traction Action is odorless traction compound for foam tires on carpet tracts. 海绵胎用于地毯路面,特点是无味 4. TRINITY TIRE TWEAK 2000 Tire Tweak 2000 softens foam tires and restores the natural traction of the rubber. Use this on top of traction compounds such as Death Grip, or Paragon Ground Effects, and it will increase the the duration of time the tire compound lasts. In other words get more traction longer! 软化海绵胎,亦可还原橡胶胎咬地力。在使用了其他胎水之后使用,可延长其他胎水的持续效果。简单的说就是用了之后更抓地,更持久。 目前常见到的应该就这几个了吧,按照广东这边的情况来看,夏天温度高时,赛前10分钟左右,涂上FXII胎水,等其自然风干,下地前将轮胎擦干就行。而冬天的话,习惯提前20~30分钟涂上胎水之后用暖胎机暖胎到下地前1~2分钟,让车子在起步时就在最佳温度为好。 PARAGON的胎水 TIRE TWEAK 2000 |
