ars, Products, Team Losi - trackback
Losi have introduced their new 810 1/8th scale RTR buggy, a package boasting the most superior power to weight ratio. Featuring a Losi 3.4 nitro engine claims to deliver the most power in its class and interference free Spektrum 2.4GHz DSM technology. Add in a lightweight aluminium chassis and the 4-wheel drive 810 Buggy RTR has it all.
Features
- Lightweight black anodized aluminium chassis
- Oversized 12mm anodized, threaded shocks
- 4mm tie rods with captured ends
- Digital servo for precise, powerful steering control
- Twin disc brakes for quick and reliable 4 wheels stopping
- Large capacity 82cc fuel tank for longer run times
- Tank clunk for fuel pickup even when rolled over
- 2-Shoe centrifugal clutch
- 450-Series, track-proven Knobby tires mounted on white wheels
- Losi 3.4cc performance engine with slide valve carburetor
- High-performance tuned-pipe designed to maximize the 3.4’s potential
- Two-stage air filter system to ensure a clean air intake
- Sway bars included for better control and handling
- Spektrum SR300 receiver with 2.4GHz DSM technology
Product Specifications
Type: 4WD Nitro Ready to Run Buggy
Scale: 1/8
Length: 17.60 in (447mm)
Width: 12.05 in (306mm)
Height: 6.85 in (174mm)
Wheelbase: 12.09 in (307mm)
Weight: 5.87 lb (2.26kg)
Chassis: Anodized aluminum
Suspension: 4-wheel independent
Drivetrain: 4WD
Tire Type: 450-Series Knobby
Motor or Engine: Losi 3.4 Nitro Engine
Radio: Losi MTX Pro Transmitter with Spektrum 2.4GHz DSM Technology
Servos: Losi digital
Wheel Size: 450-Series
Shock Type: Threaded aluminum, coil-over, oil-filled
Body: Custom screened and trimmed
Fuel Tank Capacity: 82cc
