New Engine Mounts For XB8
查看: 2006|回复: 0| [复制链接]
council 长老 Fans 发消息
发表于 05-4-16 19:58:00 |显示全部楼层 来自: 英国
Adjustable engine mount CNC-machined from premium lightweight aircraft aluminum with Xray stylish black finish and silver edging. The engine mount consists of two pieces: the adjustable bottom mount is affixed to the chassis while the upper mounts are attached to the engine.
When installing the engine mount for the first time, the slots in the chassis enable easy and comfortable gear mesh adjustment. Once the proper gear mesh is adjusted the bottom mount is fixed to the chassis. This enables the engine to be mounted and dismounted each time without another gear mesh adjustment.
The single-piece engine mounts allow easy access to the rear cover of the engine so you do not have to dismount these holders at any time. The single-piece engine mount can be easily mounted to the lower mount as it has very easy access area for a screwdriver.
The special design of the engine mount features a prolonged nose that is designed to decrease the flexibility from the middle of the XB8 chassis. The nose will stiffen the chassis and will decrease the movement between the teeth of clutch bell and spur gear, thus minimizing the chance of clutch bell or spur teeth breakage when insufficient gear mesh is present. To make the chassis stiffer, the nose can also be mounted to the chassis.
#358712 Alu Adjustable Engine Mount – Novarossi, Sirio, R&B, Max, JP
#358713 Alu Adjustable Engine Mount – Picco, Mega, Orion, LRP
#358716 Alu Stands For Engine Mount for Novarossi, RB, Max, JP, and Sirio engines
#358717 Alu Stands For Engine Mount for Picco, Mega, Orion, LRP
