[电子设备] 关于锂电的问题
查看: 1459|回复: 4| [复制链接]
263484331 论坛元老 发消息
发表于 10-7-3 01:20:53 |显示全部楼层 来自: 中国宁夏银川
小弟今天才收到电池及充电器,一直都没有用过,刚才试着充电,1800毫安电池,用0.9a去充结果充到800时就报警显示充满,这是为什么呢?请教高人解答。会不会是电池以前里面就有电?我新电池没有放电就直接充了,对电池会有影响吗?
champsjun 超级元老 发消息
发表于 10-7-3 15:01:59 |显示全部楼层 来自: 中国北京
第一第二个问题:是因为新电池都是有6成左右余电的,第3个问题:锂电到是无所谓,氢电由于有点记忆效应所以最好把电放尽了再冲
vipboy 超级元老 发消息
发表于 10-7-3 17:02:21 |显示全部楼层 来自: 中国四川内江
LS完全正解。。。。。。。。。。。。。。。。。。用啥子LIPO啊。。。。。A123不是挺好的嘛。。。。
pqrs941 RC 新手 发消息
发表于 10-7-4 14:47:44 |显示全部楼层 来自: 中国安徽合肥
Practice combos in Metin2
Québec metin2 yang:Firstly, you want to get your combo bar in the right place, there are 2 places you can have it either just above your character or at the very top of the screen. To change its position go into your options, choose the 'Game' tab and tick / untick 'Combo UI on top', personally you prefer it unticked. You can only use magic or sword skills when doing combo's, normal attack will not work. As you are aware, before you can use it again so when comboing make sure you are not using a move that hasn't cooled down yet, every time you use a sword or magic skill to attack you have to wait a short amount of time, if you do it will cancel the combo.
cheap kamas            http://www.metin2yang.cc/
Once you start Combo Mode, you will notice the combo bar appear and a green or yellow bar inside it will fly across to the right, what you need to do is press a magic or sword attack as it gets inside the 2 lines at the right side of the bar - if done correctly you will get a Bad, Good, or Excellent and it will fly across again and so you have to press a different sword or magic attack - if done wrong you will get a Miss! To always get 'Excellent' make sure you press an attack as it lands on the right line. The more you combo the smaller the 2 lines will get until you get to the 11th combo, then it will stay the same size and its all about keeping your cool and trying not to slip up.
cheapest Maple Story mesos
As a Metin2 player , Sometimes you may need bon metin2 yang . If you believe us , You can contact our customer service through live chat , we will try our best to help you . You could also Acheter metin2 yang for your characters. Just have a try. Have a good time in Metin2.
petearth 论坛元老 发消息
发表于 10-7-6 09:18:53 |显示全部楼层 来自: 中国辽宁沈阳
要看电池容量,要放电,看放了多少电的。   看充不准确,充的永远>实际容量,充电时的容量指示是指充电器放了多少容量出来,但电池消化接收了多少并不能体现的。   镍氢使用时尽量充饱、放了用。
