本帖最后由 yuhanbaby 于 10-6-10 09:12 编辑 DX3S主要特点 Now compatible with the MR3000 3-channel marine receiver and DSM2 surface receivers, in addition to DSM surface receivers.现在兼容的MR3000三通道接收机和DSM2枪控接收器,除了DSM枪控接收器。 Integrated telemetry with graphically depicted gauges on transmitter (requires DSM telemetry compatible surface receiver)*综合与图形描绘计遥测发射机(要求兼容表面用电遥测接收器)* 10-model memory 10个设置存储 Includes free bonus SR300 3-channel DSM sport receiver包括免费SR300三通道接收机用电运动 Monitor your engine or motor's operating temperature in either Fahrenheit or Celsius监控您的引擎或马达在摄氏或华氏或工作温度 Never let a low battery stop you in your tracks – the DX3S and integrated telemetry let you watch over your receiver pack's voltage to keep you in the running永远不要让一个低电池停止在您的轨道你 - DX3S和综合遥测让您看您的接收包以上的电压保持在你运行 Keep tabs on your engine's operating range-safe high-rev operation继续你的发动机的工作范围,安全的高转速运作标签 Rolling selector user interface for fast, easy programming and setup滚动选择快速,简便的编程和设置用户界面 10-character model naming 10个字符的模型命名 3 grip sizes (small, medium, large)三握尺寸(小,中,大) Adjustable Frame Rate: 11 or 16.5ms可调帧率:11或16.5ms ModelMatch ModelMatch Expert and standard modes专家和标准模式 Digital trims数字微调 Throttle Punch油门冲 Steering dual rate督导双率 Travel adjust旅行调整 Sub trims分饰件 Servo reverse伺服反向 Exponential 指数 3-timer functions 3,定时器功能 Aux/Steering channel mixing辅助/混合督导通道 Telemetry alerts遥测警报 Buzzer adjustments - high, low & off蜂鸣器调整 - 高,低和关闭 Screen contrast屏幕对比度 Transmitter battery alert发射机电池警报 Right-hand configuration (only)右侧配置(只) DX3R主要特点 Faster response time than any other spread spectrum system速度超过任何其他扩频系统响应时间 Adjustable frame rate - 5.5ms, 11ms, or 16.5ms可调帧频 - 5.5ms,11毫秒,或16.5ms Includes SR3100 DSM2 receiver包括SR3100 DSM2接收机 30-model memory 30个设置存储 Patent pending ModelMatch专利申请ModelMatch Digital trims数字微调 Graphically depicted exponential生动地描绘指数 Graphically depicted travel adjustment生动地描绘旅行调整 Trim rate adjustment修剪率调整 Steering dual rate督导双率 Steering dual rate override督导双率凌驾 Frame Rate: 5.5, 11, or 16.5ms帧速率:5.5,11,或16.5ms Switch assignment开关转让 Servo monitor伺服监控 Model reset模型复位 Model copy模型复制 Sub Trims分饰件 Three timer functions: countdown, count up and integrated 3个定时器功能:倒计时,计数和集 以上是GOOGLE翻译的网页,呵呵呵。 主要还有一点,DX3S是国产的,DX3R是马来西亚产的。 |
