Team Durango have released some details on the ‘revolutionary’ radio tray from the company’s DNX408. The radio tray is set into the chassis for the lowest centre of gravity, with only five screws holding it in place and is easy to slide the whole assembly out of the side of the car. Both servos are laid down and sit below the surface of the chassis, while the RX battery is also sunk in the chassis and centrally mounted at the rear of the car, resulting in further optimised center of gravity. The receiver itself is the only thing that sits high in the car, above the throttle servo, and the RX box has been fitted with louver type vents to keep the receiver cool in the hottest conditions and there is a removable cover to seal it up again when there’s water about. Team Durango 发放了DNX 408 "革命性"的设备架图片,这设备"架"基本上紧贴底盘以降低重心,只需五颗锣丝,整组电子设备包括AMB 都可一整组拆出,油门及转向舵机匀为平躺式安装于底盘内,比底盘边线更低,有别于一般车架。接收电池置于车架的正后方令车架的重心更集中于中心线上,接收是唯一位置较高的设备,放置在油门舵机之上,接收仓设有通风闸以保持接收不会过热,在遇到有水的情况下,DNX408有额外零件把接收仓完全密封。 |
