发表于 10-2-7 12:36:21 |显示全部楼层 来自: 中国广东广州
New from Kyosho is their 190mm competition touring car, which we have seen in various stages of development over the past few years. Called the TF6, everything is more centralized on the car and it is LiPo ready and more durable than the previous car with stronger rear drive cups. The front drive system, which we got the first view of at the DHI Cup, uses steel balls to provide forward drive between the drive cup and front drive shaft yet wont bind under suspension compression. The car is set to be released in May.
Other new items on the stand include the MP9E, which is the brushless version of the company’s 1/8th scale buggy and which will be available with or without a Team Orion electronic set. In 1/10th scale off road the new Ultima RB5 SP sees the motor moved more towards the centre line, has slightly longer rear wishbones and is supplied with velvet coated shock absorbers. Not on the stand but expected to be released at the start of summer is the new FS 4wd electric buggy which is expected to feature a new carbon chassis for LiPo saddle packs and have the motor moved further to the rear. Finally, Kyosho have the prototype of their new Mini-Z on display, which is an all new 4wd platform that is designed to accept small LiFe packs for extended run times.
发表于 10-2-7 15:38:01 |显示全部楼层 来自: 中国广东佛山
发表于 10-2-7 20:15:02 |显示全部楼层 来自: 中国广东广州
Dopo il teaser di alcune settimane fa, la Kyosho ha presentato la nuova buggy elettrica in scala 1/10 Kobra EP Fazer. Dalle immagini il modello sembra ancora in fase di sviluppo e non sono state rilasciate specifiche tecniche, data di lancio e costi.
usa2010 RC 新手 发消息
发表于 10-2-16 16:44:06 |显示全部楼层 来自: 美国
玩电的好啊
alexlau1120 终极 Fans 发消息
发表于 10-2-17 21:09:38 |显示全部楼层 来自: 中国广东佛山
KYOSHO的红色真的很诱人,就是价格太高以及太偏门了!
caolemeng 超级元老 发消息
发表于 10-3-2 03:42:53 |显示全部楼层 来自: 中国河南焦作
一个字\····帅气
