本帖最后由 km-group 于 10-2-2 10:19 编辑 KM 1/10 Scale Super Luxury Full Option 4WD GP Touring Car H-K1 (Proto-type III) (You will definitely need in the worldclass racing !) Special Features: 1. Bat-Head type front bumper—Creat air-dynamic down force (First creative design in the world !) 2. Carbon front chassis plate—Provide different setting & front belt protecting (First creative design in the world !) 3. Front carbon belt adustor holder—Provide easy & quick change function (First creative design in the world !) 4. Rear carbon belt adjustor holder—Provide easy & quick change function (First creative design in the world !) 5. Air-ship type fuel tank—Quick change and air-dynamic function with extremely low CG. (First creative design in the world !) 6. Air-dynamic main chassis—Creat rapid air flowing function. (First creative design in the world !) Will be announced with the proto-type IV in March. 7. Aluminium front bulkhead—Provide strong & rigidity structure 8. Aluminium rear bulkhead & gear box—Provide strong & rigidity structure 9. Roll-bar with bearing—Provide easy & simple balancing 10. Quick change & easy adjustment design for front upper arm and rear bottom arm pins. Super Luxury Optional Parts will be included as standard: (Subject to final announcement by KM Group at the beginning of April) 1. Full car aluminium parts using A7075-T6 with special hard coating. 2. Full car equip with aluminium hard coated pulleys 3. Telfon coated aluminium front & rear shocks 4. Full bearings with two ceramic bearings for two speed. 5. Titanium 64Ti turnbuckle. 6. Titanium 64Ti middle shaft 7. Titanium 64Ti pivot balls 8. KM aluminium front axle. 9. KM carbon brake plate with special high friction brake pad. 10. Aluminium hard coated servo saver. 11. KM special ultra light weight clutch system. 12. Full car equip with low friction belts 13. Carbon & aluminium brake arm. 14. Carbon battery plate. 15. Carbon middle belt stand. 16. Carbon middle mount collar. 17. Carbon 2 speed shaft collar. 18. Carbon rear stiffener. 19. Front spring steel universal shaft. |
