Hikaru, 我也google了一下Toyota GT-1 的历史,原来她在99年的Leman排位赛成绩也非常好的(头3位都是Toyota GT-1,Martin Brundle在1号车), 只是头二车发生了意外没有完成,三车得第二。 以下是车的数据: engine Twin Turbo V8 displacement 3600 cc / 219.7 in³ bore 86.0 mm / 3.39 in stroke 77.0 mm / 3.03 in compression 9.0:1 power 447.4 kw / 600.0 bhp @ rpm rpm specific output 166.67 bhp per litre bhp/weight bhp per tonne torque 650.0 nm / 479.4 ft lbs @ rpm rpm body / frame Carbon Fibre Composite front brakes Carbon Fibre Discs f brake size mm / in rear brakes Carbon Fibre Discs r brake size mm / in weight 900 kg / 1984 lbs wheelbase 2800 mm / 110.2 in front track 1600 mm / 62.9 in rear track 1644 mm / 64.7 in length 4840 mm / 190.6 in width 2000 mm / 78.7 in height 1125 mm / 44.3 in transmission 6-Speed Sequential http://www.supercars.net/cars/1804.html |
