Shepherd Velox V10
查看: 4128|回复: 15| [复制链接]
发表于 09-11-14 11:32:51 |显示全部楼层 来自: 中国澳门
Overview Shepherd Velox V10 features
- Innovative 'Direct-V-Brake System'
- Front and rear CVDs included
- Extra stability by rear upper wishbone
- Downstop separately adjustable in the front
- Easy differential maintenance
- Adjustable servo saver for quick Ackerman adjustment
- Adjustable servo saver position
- Well-proven 'Velox Revolutionary Shock System'
- 'Velox Competition Clutch' with extra strong spring
- Hard-coated aluminium pinions
- Front and rear belt tension adjustable without disassembly
- Adjustable front anti-roll bar
- Improved lightweight 2-Speed gearbox
- Changing gears without needing to re-adjust the engine block
- Precision machined 7075 T6 aluminium chassis plate
- Blue anodized aluminium bulkheads and hinge pin brackets
- Shock towers made of premium German carbon fibre
- Super flat, vibration free, top mounted fuel tank
- Quick roll-centre adjustment in the front and rear
- Wheel axles mounted from the outside for easy maintenance and set-up
- Adjustable front and rear off-set
颜俊文 论坛元老 发消息
发表于 09-11-14 13:11:13 |显示全部楼层 来自: 中国广东中山
叫什么名字啊
发表于 09-11-14 14:14:55 |显示全部楼层 来自: 中国广东广州
羊咩咩啊~~~~好锺意他的刹车系统啊!
autohero 长老 Fans 发消息
发表于 09-11-14 14:26:13 |显示全部楼层 来自: 中国辽宁沈阳
很漂亮的羊仔    线刹啊   超赞
shun 终极 Fans 发消息
发表于 09-11-14 14:41:36 |显示全部楼层 来自: 中国广东东莞
羊咩咩啊~~~~好锺意他的刹车系统啊!
乐桦 发表于 09-11-14 14:14
那還不快點出手....
caoqidong 终极 Fans 发消息
发表于 09-11-14 21:13:49 |显示全部楼层 来自: 中国贵州黔东南苗族侗族自治州
亮车一部,坚定完毕
PROKIMI 论坛元老 发消息
发表于 09-11-14 21:15:41 |显示全部楼层 来自: 中国上海
又是走的贵族路线~穷人啊
CORN 元老 Fans 发消息
发表于 09-11-15 02:40:15 |显示全部楼层 来自: 中国台湾
煞車後碟盤不是會熱嗎?..這樣皮帶輪會不會熔掉阿..
wq771014 长老 Fans 发消息
发表于 09-11-15 11:36:56 |显示全部楼层 来自: 中国重庆
听说   可以破百?????????????????????
发表于 09-11-16 11:52:30 |显示全部楼层 来自: 中国广东广州
那還不快點出手....
shun 发表于 09-11-14 14:41
前已经准备好了~~~~就等羊咩咩了
