[电子设备] Reedy 5S 18.5V and 6S 22.2V Competition LiPo
查看: 1768|回复: 1| [复制链接]
nivea 金牌 Fans 发消息
发表于 09-10-15 15:36:46 |显示全部楼层 来自: 中国广东广州
1:8电车用的,40c
Reedy’s hard case 40C 1:8 LiPo batteries are now available in 5S 3800mAh 18.5V and 6S 3100mAh 22.2V configurations for those who want the added efficiency that higher voltage delivers. These batteries fit perfectly in Team Associated’s RC8e, SC8e, and RC8Te and are suitable for use in many other chassis’.
For minimum resistance and maximum power delivery, 10-gauge wires are pre-wired and ready to add your favorite connector. Balancing harness makes balancing and balance charging simple and convenient while a hard case helps protect the batteries from crash damage.
Reedy LiPo 3100mAh 6S 22.2V 40C
  • Length: 138mm
  • Width: 46mm
  • Height: 49mm
  • Discharge: 124A cont., 155A burst
  • Weight: 551g
  • Connector: none; with 10-gauge wire
Reedy LiPo 3800mAh 5S 18.5V 40C
  • Length: 138mm
  • Width: 46mm
  • Height: 49mm
  • Discharge: 152A cont., 190A burst
  • Weight: 535g
caiwenping 论坛元老 发消息
发表于 09-10-15 18:48:32 |显示全部楼层 来自: 中国上海
好大一坨!
