You can calibrate your tire warmers with your thermometer. Calibration is required when tire warmers are changed or other purpose. 1.With push up key and hold, input 12V power.Stop pushing button. FL will blink first. Check the temperature of FL with your thermometer. :Match the temperature to the value. :Move cursor to next step. Calibrate FR-RL-RR warmers as same way. If you push key on FL, CTX-W will save all calibration data and will restart itself. |
