bobby_chan 金牌 Fans 发消息
发表于 09-6-9 22:10:02 |显示全部楼层 来自: 中国上海
EP Micro Helicopter Minium AD
CALIBER 120 Readyset
No.20101RS   Readyset
□Available : 18 Sep 2008
Lightweight full function electric helicopter fits on the palm of your hand and features cyclic control with the included gyro and 4-channel radio system!
Enjoying flying backwards and hovering around your living room.
The revolutionary innovation of MINIUM series has produced a new breakthrough in the form of a technologically sophisticated full-function micro helicopter. Similar to large helicopters, the CALIBER 120 is the first production-model palm-top sized helicopter to feature cyclic control enabled through the 4-channel, with pre-mounted gyro. Other small helicopters have only used tail-rotor and motor control to govern lateral and vertical movement, but this sophisticated machine uses a built-in swash plate with stabilizer and main rotor to allow free control for hovering, left / right and up / down movement to recreate a breathtakingly real helicopter flying experience. Optimal use of carefully tested materials result in a strong structure weighing only 30g that realizes both easy maneuverability and keeps damage to a minimum in the event of a crash. The durable main rotor can take hard contact with the ground and offers a far more rewarding flying experience compared to toy helicopters. The amazing flight performance is proof the ultra lightweight design has eliminated all barriers to real helicopter flight. As with all MINIUM models, this one comes as a completely pre-assembled Readyset. With pre-flight setting adjustments complete, simply insert batteries in the transmitter and charge the included Li-Po battery from the built-in battery charger and get ready to takeoff from your dining table for a joy flight around your living room. Imagine hovering and touching down on the coffee table! The CALIBER 120 is much more than flying a machine, it is an opportunity to experience the fascination of helicopter control!
Packed with the technology developed with the MINIUM airplane. Lightweight design delivers easy flight control. Resistant to hard contact so you can have many relaxed and carefree flights.
Introduces 4-channel system with cyclic control to a helicopter of this size for forward/reverse, left/right, up/down maneuverability and hovering capability.
Carbon tail boom etc. contributes to the lightweight structure. Tail rotor features coreless motor for sharp yaw control.
Newly developed multifunction transmitter features a large LCD to display data for voltage, digital trim offset volumes and each control mode. Provides complete visibility of control settings.
Train with confidence with the included training safety bar.
Ultra-safe 4-channel radio control system uses world standard 2.4GHz system that automatically scans a 75-wave spectrum for an open frequency to use. Up to 24 helicopters can be flown at the same time.
All control inputs are equipped with 19-step digital trims for precise adjustment. Tone indication and display provide clear understanding of control settings.
  • Completely assembled Readyset includes newly developed 4-channel 2.4GHz KT-20 radio control system and special Lithium Polymer battery pack.
  • Automatically scans for open frequencies across a 75-wave spectrum on the 2.4GHz band for ultra-safe control. Up to 24 aircraft or helicopters can be flown at the same time.
  • Connects automatically once transmitter is registered to the receiver. (Comes pre-registered at time of shipment).
  • Transmitter features new design built-in antenna that delivers more effective signal emission.
  • Display shows values of the 19-step digital trim settings which are also indicated with tone signals.
  • Transmitter can be paired and used with 2nd or even 3rd aircraft.
  • Advanced design features two special servos, receiver, motor control amp and gyro in an ultra lightweight structure.
  • Cored motor delivers the necessary torque for the main rotor while a coreless motor produces optimal response from the tail.
  • Transmitter features built-in quick battery charger that can be used while the transmitter is used for flight control.
  • Chose Mode I or Mode II flight styles, which is shown on the display.
  • Push in the elevator stick to turn Expert Mode ON/OFF to use the dual-rate function for adjusting the aileron and rudder angle.
  • Transmitter can be used with both the MINIUM AD airplane or helicopter series. **Cannot be used with 3-channel MINIUM airplane.
  • Swash plate mechanism enables control movement around the roll and pitch axis, just like large size helicopters. Inclusion of gyro also provides sure control of the tail.
  • Lightweight structure optimizes strength and flexibility to realize an easy-to- fly, robust and convenient machine.
< What is a Readyset? >
A Readyset is a fully assembled model that includes nearly everything you need to fly.
Color scheme is complete so only consumables like batteries and fuel are required so you can start operating the model without delay.
< Readyset Contents >
  • Fully assembled helicopter complete with basic setting adjustments.
  • 3.7V-150mAh Lithium Polymer battery pack
  • 2.4GHz band 2-stick transmitter (built-in charger) with digital trims
  • Training safety bar
< Required for Operation >
  • 4 x AA-size alkaline batteries for transmitter
  • Note) Oxyride batteries cannot be used
Technical Data
Length
205mm
Width
45mm
Gear Ratio
7:1
Weight
30g (approx.)
R/C System
Special 2.4GHz 4-channel R/C System
Main Rotor Diameter
179mm
Tail Rotor Diameter
45mm
Operation Method
Main: Cyclic pitch control / Tail: motor speed control
This R/C model is not a toy!
Correct assembly and maintenance and choice of appropriate flight location is required for the safe operation of this model. Failure to use responsibly and perform required safety checks can cause fatal accidents. Beginner flyers should never fly solo.
壁恺光电 论坛元老 发消息
发表于 09-6-10 14:25:46 |显示全部楼层 来自: 中国浙江杭州
京商的2.4G不会只卖400的~
dglilo 发表于 09-6-8 22:20
太队了 光控都远远不够
bprince 元老 Fans 发消息
发表于 09-6-10 17:19:59 |显示全部楼层 来自: 中国浙江温州
多少 米啊。。。这个
x57 终极 Fans 发消息
发表于 09-6-10 20:15:24 |显示全部楼层 来自: 中国北京
按京商传统估计1000差不多
开赛车的猪 超级 Fans 发消息
发表于 09-6-10 22:55:41 |显示全部楼层 来自: 中国上海
PM价格啊!!小东西不错啊!
cqhdd 论坛元老 发消息
发表于 09-6-12 13:33:03 |显示全部楼层 来自: 中国重庆
看起来不错哦
ypat 高级 Fans 发消息
发表于 09-6-12 15:36:28 |显示全部楼层 来自: 中国福建厦门
比较关心马达寿命……
以前华科尔出的微型据说马达几分钟就要换一个……
