DYGM 超级元老 发消息
发表于 09-5-26 14:01:13 |显示全部楼层 来自: 中国北京
供需要的朋友参考,也欢迎用过的朋友进来发表下感受,有别的好充电器,也请大家补充进来,并辅以介绍,小弟最近也打算入手这类充电器:
此类充电器特点:
1.充电通道均为独立
2.Delta V检测式充电
3.有LCD显示状态
4.5号AA和7号AAA通吃(甚至能使用更广泛的Ni类电池型号)
5.支持充放电
MH-C9000 WizardOne Charger-Analyzer for 4 AA / AAA:
4通道独立充,有电池分析和Match功能
Four independent slots
It's like having four charger-analyzers for AA and AAA NiMH / NiCD batteries.
Large backlit LCD display
Digitally displays capacity, voltage, time and current.
Endless programming possibilities - over 10,000 ways!
29 selectable charging and discharging rate. Charging current from 0.2A to 2.0A and discharging current from 0.1A to 1.0A in 0.1A increments.
Five modes of operation
Charge: Recharges the battery at the selected rate.
Suitable for batteries used frequently.
Refresh & Analyze: Charges the battery, rest for one hour, discharge, rest again, then recharges it. Selectable charging and discharging rate.
Suitable for batteries stored for more than two weeks but less than 3 month or those showing poor performance.
Break-In: Also known as IEC capacity measurement and "Battery Forming". Charges battery at 0.1C for 16 hours, rest for one hour, discharges battery at 0.2C, then recharges again at 0.1C for 16 hours.
Suitable for new batteries and those stored for more than 3 month.
Discharge: Discharges the battery at the selected rate.
Cycle: Performs charge-discharge cycle for up to 12 times with discharge capacity stored in memory. Recharges battery after final cycle.
New ways to take care of your batteries and maximize runtime!
Battery Matching
In most devices, usually two or more batteries are used together. When batteries are used in a series, the performance is limited by the worst one. In other words, one poorly performing battery can significantly reduce the device runtime.
Battery matching refers to grouping batteries with similar 揳ctual?capacity. To perform this, use the Refresh & Analyze mode to determine the battery capacity. Group batteries with capacity within about +/- 5% of the rated capacity.
Battery Forming
New batteries and those stored for extended period become chemically deactivated. Battery forming is a charge-discharge-charge cycle which forces a full charge into the battery at a very slow rate. This process activates the battery. In certain cases, it needs to be repeated two or three times.
Battery forming can be performed using the Break-In mode.
Delivers just the right charge
Independent negative delta V, temperature and timer protection eliminates over and undercharging.
Super light travel worldwide power supply and 12V compatible
Worldwide 100-240V switching adapter - light weight and small. Also compatible with 12V input. Will work on car when used with the optional cigarette lighter adapter.
Charging Current:Programmable from 0.2A to 2.0A in increments of 0.1A
Topoff Charging Current:100mA
Maintenance Charging Current:10mA
Discharge Termination:Voltage 1.00V
Discharge Current:Programmable from 0.1A to 1.0A in increments of 0.1A
Capacity Storage Memory:12 (Cycle mode only)
Supported Capacity:100 to 20,000mAh.
Charger Input Power:12V 2.0A
Adapter Input:100-240V 50/60Hz
MH-C808M Ultimate Professional Charger for Eight AA/AAA/C/D NiMH / NiCD:
8通道独立充,除了AA和AAA,还能充C和D,也就是最大能到同时充8个1号电池
One to Eight AA / AAA / C / D NiMH or NiCD batteries in any combination
It's like having eight chargers! The 7th generation Powerex microprocessor features a 0.001V resolution delivering just the right charge!
First charger designed for today's high performance batteries
The MH-C808M is designed for today's ultra high capacity C & D batteries with rapid charging current. Charging time for a 11,000mAh D battery is around 5 hours, while other products may take up to 40 hours to complete.
Charging Rate: 2.0A for AA / C / D and 0.7A for AAA
Recharge AA / AAA in one hour and C / D in 1 to 5 hour regardless the number of batteries.
Comprehensive LCD display with white backlight
Easy to understand English-based LCD displaying charging status for each battery independently.
Simply Rugged: No Spring-loaded Contacts
Unlike other universal chargers, the Powerex MH-C808M uses rugged fixed contacts rather than spring-loaded ones, enhancing product reliability. It also features a rugged DIN power connector found only in professional products.
Selectable Soft and Rapid Charging Mode
The MH-C808M provides user with the option to choose between a soft charge and a fast charge mode. The Soft mode delivers the highest battery life and allows 100% compatibility with older, lower capacity batteries.
Low-Temperature Charging Algorithm
The MH-C808M is the coolest rapid charger in Powerex's line of professional products. Low charging temperature maximizes battery life and performance.
Built-in Deep Battery Conditioning System
The MH-C808M is embedded with a high-rate battery conditioner that will charge, deep-discharge and recharge batteries automatically.
Heavy Duty Worldwide AC Adapter
The unit includes a heavy duty switching AC power supply. The 100-240V 50/60Hz universal adapter employs a rugged DIN connector for reliable contact.
Supported Batteries:One to Eight AA, AAA / C /D NiMH or NiCD
Rapid Charge Current:2000mA (AA, C, D), 700mA (AAA)
Charge Time:AA: 1 Hour (Normal), 2 Hour (Soft Charging), C / D: 1-5 Hour (Normal), 5-10 Hour (Soft Charging)
Power Supply:Worldwide Switching AC Adapter 100-240V 50/60Hz with removable cord
MH-C801D Eight Cell 1-Hr Charger:
MH-C808M的简化版本,只能对付AA和AAA电池,其他与808M一致
MH-C800S Eight Cell Smart Charger:
MH-C801D的简化版本,充电电流减小一半,其他与801D一致
La Cross Alpha Power Battery Charger BC-9009:
4通独立充:
Works with all NiCd and NiMH “AA” and “AAA” Rechargeable Batteries
All Modes Automatically Default to 200mA Charge (the optimal setting for prolonging battery life)
Charge Both “AA” & “AAA” Rechargeable Batteries Simultaneously
Overheat Detection to Protect Over-Charging
Tons of Accessories Included
Dimensions:
Charger: 3.0" x 5.1" x 1.5"
All Features:
LCD shows capacity for each battery when charging is complete
Charges AA & AAA rechargeable batteries simultaneously
Will not charge defective batteries
Select different charging current for each channel
Automatically switches to trickle charge when charging is complete to ensure maximum battery capacity
Automatically defaults to 200mA charge (the optimal setting for prolonging battery life)
Overheat detection to protect over-charging
7 Easy to Use Function Keys
Charge Mode (charging current)
Discharge Mode (discharging current)
Refresh Mode (time elapsed)
Test Mode (accumulated capacity)
Included Accessories:
4-”AA” NiMH 1.2v Batteries
4-”AAA” NiMH 1.2v Batteries
Durable Nylon Travel Bag
AC Power Adapter
4-”C” Size Battery Adapters
4-”D” Size Battery Adapters
Specifications:
Charges Battery Types:
AA & AAA NiCd and NiMH
Input Voltage for AC/DC Adapter:
100-240 VAC
Charging Current Range:
200 mA - 1800 mA
The end!
synoman 金牌 Fans 发消息
发表于 09-5-26 14:23:55 |显示全部楼层 来自: 中国上海
顶级了,功能还不及模型用的多,为了个5号花上500-1000值吗
DYGM 超级元老 发消息
发表于 09-5-26 14:32:23 |显示全部楼层 来自: 中国北京
synoman 发表于 2009-5-26 14:23
全部是独立的通道……
jog 超级元老 发消息
发表于 09-5-26 18:59:16 |显示全部楼层 来自: 中国北京
看LZ想用这些NB的充电器干什么用了,没有最好用,但有最合适的选择。
我觉得也就是玩miniz值得用这些充电器。可以不用平电,充电速度也快,温度也不高。
nankey 超级元老 发消息
发表于 09-5-26 19:11:31 |显示全部楼层 来自: 中国北京
推荐品威的,有兴趣自己查吧,我在用
synoman 金牌 Fans 发消息
发表于 09-5-26 22:13:17 |显示全部楼层 来自: 中国上海
一般式不用这样的,迷你车是个好选择,顶七楼
Himalaya 超级元老 发消息
发表于 09-5-27 10:54:36 |显示全部楼层 来自: 中国北京
莫非LZ这次又要奔 mini-Z 而去?
DYGM 超级元老 发消息
发表于 09-5-27 11:32:28 |显示全部楼层 来自: 中国北京
非也哦,是要给给偶的12颗AA GP绿色宝宝选个好的管家哦~
nankey 超级元老 发消息
发表于 09-5-27 12:29:08 |显示全部楼层 来自: 中国北京
我是品威y6+吧,带上位机,带放电,0三角峰值截止,支持查看曲线。
DYGM 超级元老 发消息
发表于 09-5-27 16:38:05 |显示全部楼层 来自: 中国北京
nankey 发表于 2009-5-27 12:29
查了下,这个的确很强大~!
