本帖最后由 hzf9911 于 10-1-15 01:47 编辑 哈哈~笑话啦 SET-UP MOD ST setting rang is NOR and SHR.The default setting is NOR.NOR can be used with both Anaiog and Digital servos.SHR is used with Digital servos to give them a faster response time. 这是M11X说明书上,调整数码舵机和模以舵机的说明。 在M01菜单SET-UP的SYSTEM[mod]BIND(在选择接收机模式)M11X原配的接收机应该选TYPE:FH3F&FH3 然后右下角是选择舵机的工作模式:NOR(模以&数码)SHR(可以发挥数码舵机的极致速度) |
