Lightning Stadium RR
查看: 1730|回复: 0| [复制链接]
发表于 04-10-1 00:05:00 |显示全部楼层 来自: 英国
Coming soon from Hot Bodies is the 1/8 Scale Lightning Stadium RR (RTR).
The Lightning Stadium chassis is long for extra stability, good handling and a smooth ride while the suspension arms are much longer than the lighning2 buggy arms. Both the front caster blocks and rear hub carriers have a dirt deflecting shield to keep dirt out of the drive shaft and bearings.
The servo deck is low profile and the steering servo is mounted in the laydown position to get more weight down low. The radio box is also low profile as well as the fuel tank which is wide and low for a low center of gravity.
The Lightning Stadium comes standard with the new Power Factory engine, that has an all new carb with tricked out porting that makes the truck really fast while the drivetrains spiral-cut gears are smoother and more durable than standard gears.
Finishing off the Lightning Stadium RR is a stylish pre-printed and trimmed body and racing style tires and dish wheels that provide excellent grip on almost all surfaces.
Kit includes:
• .26 Power Factory Engine w/Jump Start
• Long Wheelbase Main Chassis
• Front and Rear chassis Braces
• Spiral Bevel Gears
• 50 Tooth Center Gear
• Composite Long Suspension Arms
• 4mm F/R Shock Towers
• Front CVA Joints
• F/R Long Shocks
• Full Sealed Bearing
• Racing Wheels & Tires
• Steel Differential Gears
• 2 Pc. Racing Clutch
• Low Profile Stadium Truck Body (Yellow)
• F/R Sway Bars
• Radio and Radio Gear
• High Torque Steering Servo
• Fuel Bottle
• Glow Starter
