Tamiya以前也有一套红色的工具套装,这次应该是换了外观。 Tamiya is this handy compact tool set, which includes most of the tools you would ever need when working on your car. Supplied in a base stand with transparent cover, the set includes 2 philips head screw drivers, a flat head screwdriver, a 5.5mm and 7mm nut spinner and a 1.5mm, 2.0mm and 2.5mm hex driver. Also supplied with the set is a large diameter handle that the tools can sit into to give them more leverage if needed. Available from tomorrow. |
