cn版本的27m变频高频头可以调整12个频率 ,这句话非常关键 26MHz—27MHz 频段,海/车模为:(括号里是FUTABA、JR设备所配的飘带颜色) 26.975 MHz 27.125 MHz 26.995 MHz (茶色) 27.145 MHz (黄色) 27.025 MHz 27.175 MHz 27.045 MHz (红色) 27.195 MHz (绿色) 27.075 MHz 27.225 MHz 27.095 MHz (橙色) 27.255 MHz (兰色) 貌似27.145在第八频段,是否这样判断?? ADDITIONAL COMMENTS: There is no instruction manual for the synthesized module. Changing the channel, you have two pots, labeled 0-9. From left-to-right, you set the first pot to zero, the second pot you assign the channel number: 0 1 = A1 0 2 = A2 0 3 = A3 0 4 = A4 0 5 = A5 0 6 = A6 When you assign the module to a new channel, Turn the transmitter OFF while making the change, turn it back ON, wait for a few seconds. The servo should twitch letting you know you have a signal. |
