DYGM 超级元老 发消息
发表于 09-2-5 11:31:12 |显示全部楼层 来自: 中国北京
终于有人出了这个Spec的充电器……
Specification
Operating input voltage
DC 11~18 V
Idling current
approx. 100mA
Charge/discharge power
max. 160/25W per output
NiCd/MH
1~22 cells per output
LiIo/LiPo/LiFe
1~8 series per output
Pb
2~ 28V per output
Charge current
0.1 to 9.0A
Discharge current
0.1 to 5.0A
No. of cycles
up to 10 times, N/A for Lixx
Battery data memories
up to 5 data per battery-type
Battery capacity range
100 ~ 65000mAh
Delta-peak sensitivity
zero, 5 ~ 20mV adjustable
Trickle charge current
off, 50 ~ 300mA adjustable
Current drain in balancer
200mA/cell
Weight
1100g
Dimension
200 x 150 x 55 mm
User's setting-up parameters
Lithium battery type
LiIo:3.6V, LiPo:3.7V, LiFe:3.3V
Lithium battery charge mode
Normal, Balance, Storage, Fast
NiCd/NiMH charge mode
Normal, Linear, Reflex
NiCd Delta-peak voltage sensitivity
disable, delicate, 5 to 20mV adjustable
NiMH Delta-peak voltage sensitivity
Pb battery charge mode
Linear, Pulse
Battery temperature cut-off
Off, 20 to 80C
Waste time between charge/discharge cycle
zero to 60 minutes.
Trickle charge mode
Off, 50 ~ 300mA adjustable
Integral timer limit for safety
Off, 10 to 1380 minutes
Maximum charging capacity limit for safety
50 ~ 120%
Key beep and buzzer sound
ON/OFF, melody selectable
Input power low alert
10 to 11V
LCD back-light brightness
Off, 1 ~ 8
-  Operating software
   The operating program in this charger is executed with mutual links and communications with every components to prevent any possible error, so it introduces the maximum safety. Especially, the charging algorithm is so multifarious that you can select the best program to suit your requirement. And BC8DX has a large LCD for showing various informations including charge/discharge graphs during the process.
- High-power dual output circuit
   BC8DX employs the circuit that features two totally independent but identical high-power outputs which are powered as much as 160watts each. As a result, it can charge or discharge up to 44 cells of NiCd/NiMH or 16 series of Lithium batteries simultaneously. Furthermore, the twin-fan cooling system is so efficient that can hold such a power without any trouble of running the circuit.
-  Dual Individual voltage balancer for Lithium batteries
  BC8DX has individual cell voltage balancers at both outputs. So it does not need any balancer separately when charging Lithium batteries (LiIo/LiPo/LiFe) for voltage balancing.
-  Balance individual cells on discharge
  BC8DX also can monitor and balance individual cells of the Lithium battery pack during the discharge process as well as ‘FAST’ and ‘STORAGE’ mode. If the voltage of any one cell varies abnormally, the process will be stopped with the error message.
-  Accept various types of Lithium battery
  BC8DX can accept three types of Lithium batteries - LiIo, LiPo and LiFe. They have different characteristics by their chemistry. You can select any one of them that you are going to process before the job. For their specifications, refer 'Warnings and safety notes' section.
- Maximum safety
  Delta-peak sensitivity : The automatic charge termination program works on the principle of the Delta-peak voltage detection. (NiCd/NiMH)
    Auto-charge current limit : When charging NiCd or NiMH at 'AUTO' current mode, you can set the upper limit of charge current to avoid from feeding high current to the battery. This is very useful when charging the low impedance and small capacity NiMH battery in 'AUTO' mode.
   Capacity limit : The charging capacity always calculated by multiple of the charging current and time. If the charging capacity exceeds the limit the process will be terminated automatically when you set the maximum value.
   Temperature limit : The temperature of the battery on charging or discharging will be raised by its internal chemical reaction. If you set the limit of temperature the process will be expired forcibly when the limit has been reached.
   Processing time limit : You can also restrain the maximum processing time to prevent any possible defect.
-  Cyclic charging/discharging
    Perform 1 to 10 cycles of charge>discharge or discharge>charge continually for battery refreshing and balancing at both outputs.
-  PC based analysis using USB communication
    For technical expert, BC8DX offers PC based program can analysis the characteristic of the battery via USB port. It shows a graph of voltage, current, capacity and temperature curves. It also shows the individual voltage of each cell in the Lithium battery pack. This program can run on both outputs with single USB link to PC.
Accessories
EAC110
Temperature sensor cable
Standard
EAC117
4mm gold banana plug with silicon cable and alligator clips
Standard
EAC300
Program kit for PC (CD + USB cable)
Standard
EAC13X
Balance adaptor board for Lixx
Optional
[ 本帖最后由 DYGM 于 2009-2-5 11:36 AM 编辑 ]
遥控大猫 超级元老 发消息
发表于 09-2-5 11:56:51 |显示全部楼层 来自: 中国北京
太过分了...
有人用过Maxpro X6没 准备买这个了 960价钱长期不靠谱 老王又不赶紧把他的0610给二手了 hoho
Himalaya 超级元老 发消息
发表于 09-2-5 12:29:23 |显示全部楼层 来自: 中国北京
注意最后一句,平衡接头(成本极低的玩意)竟然要单独够买??
型号有点受不了,国内不下十几种的山寨 XX6 XX8 已经受够了。以至于看到这个原版的型号都觉得山寨。
DYGM 超级元老 发消息
发表于 09-2-5 16:42:44 |显示全部楼层 来自: 中国北京
原帖由 Himalaya 于 2009-2-5 12:29 发表
啊哈哈,的确如此……国内山寨版本之多、之烂,几乎毁掉了原厂原本光辉的品牌形象……
[ 本帖最后由 DYGM 于 2009-2-5 04:43 PM 编辑 ]
Himalaya 超级元老 发消息
发表于 09-2-6 15:32:51 |显示全部楼层 来自: 中国北京
见到卖了,喊价 US$350。
XMOLA 论坛元老 发消息
发表于 09-2-6 15:39:22 |显示全部楼层 来自: 中国广东潮州
这个价钱还不如选择0610iDUOII
DYGM 超级元老 发消息
发表于 09-2-6 21:22:37 |显示全部楼层 来自: 中国北京
LS说的是,BC8 DX耀眼的地方就是LCD了,如果Duo也能有大屏,就爽大了……真是鱼和熊掌……继续期待价格合理的高规格充电器……
遥控大猫 超级元老 发消息
发表于 09-2-6 21:42:00 |显示全部楼层 来自: 中国北京
原帖由 Himalaya 于 2009-2-6 03:32 PM 发表
见到卖了,喊价 US$350。
你啥时候换充电器啊 等着你喊价呢嘿嘿
Himalaya 超级元老 发消息
发表于 09-2-8 01:25:11 |显示全部楼层 来自: 中国北京
回复 8# 的帖子
今天受了点刺激,真想换 Duo II 了。上了 1/8 EP 才知道电力永远不够用。
遥控大猫 超级元老 发消息
发表于 09-2-9 13:52:47 |显示全部楼层 来自: 中国浙江杭州
Himalaya 发表于 09-2-8 01:25
嗯嗯 跑1/10的好处就是 一台inet 一排电 足够了 连拆下来都不用
换的时候告诉我哈
