[遥控设备] Sanwa - RDS8000 2.4GHz Set Model 1
查看: 2187|回复: 0| [复制链接]
ego 超级元老 发消息
发表于 09-2-3 13:52:44 |显示全部楼层 来自: 中国广东广州
Sanwa RDS8000 2.4G 八通道遥控器上市!适合各种遥控飞机和直升机使用
top-quality digital radio, the RDS8000 is noted for its ease of operation and programming. Helicopter, fixed wing aircraft and sailplane pilots will all benefit when using the standard features of the RDS8000.
Whether flying a basic model or one that requires advanced features, the RDS8000 can do it all! One of the key features of the RDS8000 is the ability to use both basic or advanced program menu.
The RDS8000 makes programming easier by allowing you to turn off any programming screen not required. Because it uses Airtronics’ FHSS 2.4GHz communications technology you never have to worry about an ‘open frequency’. Fly any time with confidence.
Features
  • 8 channels
  • 10 models program
  • Fully configurable menu structure
  • 2.4 GHz
  • Exponential stoppwatch
  • dual rate
  • Reset function
  • Fail Safe
  • Throttle Cut
  • Mode selection
  • switch change
  • Includes 4xSRM-102 servos
