ego 超级元老 发消息
发表于 09-2-1 00:37:44 |显示全部楼层 来自: 中国广东广州
Team Associated 的新款电动后驱小货车SC10终于面世!SC10基于6次获得ROAR National Championship-winning RC10T4为蓝本进行开发!
SC10 Kit Features:
  • Based on a lengthened version of the 6-time National Champion RC10T4 platform
  • Realistic short course racing truck .040” polycarbonate body
  • Chassis side nerf bars
  • Trick KMC™ style wheels and aggressive tread multi-terrain scale tires with re-enforced sidewalls
  • Realistic bumpers front and rear for maximum durability
  • Rubber AE logo mud flaps
  • 2.6:1 ratio gearbox equipped with sealed gear differential
  • Two spur gears included: 75 tooth for brushless stock and 87 tooth for brushed and modified motors
  • Efficient dual-sided, externally adjustable slipper clutch
  • Molded composite low-CG chassis
  • Hinged battery hold-down strap fits up to 8-cell battery pack
  • Set-screw secured antenna tube
  • Durable front and rear body mounts
  • 14 rubber-sealed ball bearings
  • Rugged steel turnbuckles for quick and easy suspension adjustments
  • Fully adjustable suspension geometry
  • Angled bellcrank “coplanar” steering with integral servo saver
  • Vertical ball end roll-center adjustments front and rear
  • Blue aluminum shock bodies
  • Steel dogbone rear axles
  • Many Factory Team and Reedy option parts already available!
SC10 Specifications:
  • Scale: 1:10
  • Power : Electric
  • Length: 550mm
  • Width: 293mm
  • Track: 245mm
  • Weight: 2080g
  • Wheelbase: 327mm
  • Internal Gear Ratio: 2.6:1
  • Drive: 2WD
Note: SC10 shown equipped with items NOT included in kit: Reedy battery, XP servo, pinion gear, LRP ESC, motor, and receiver. Body comes clear. Assembly, painting and decals required. Team decals sold separately.
我是小新jzy 超级元老 发消息
发表于 09-2-1 03:26:19 |显示全部楼层 来自: 中国陕西西安
避震好细喔!~~~
Himalaya 超级元老 发消息
发表于 09-2-1 12:52:48 |显示全部楼层 来自: 中国北京
竟然还有后挡泥板。仿真功夫做到家了。
andhows 论坛元老 发消息
发表于 09-3-5 03:12:52 |显示全部楼层 来自: 中国浙江杭州
找到一些 照片 。。。
tony1111xie 论坛元老 发消息
发表于 09-3-5 10:11:04 |显示全部楼层 来自: 中国陕西西安
看上去很不错啊 呵呵
弱水三 超级元老 发消息
发表于 09-3-5 10:26:42 |显示全部楼层 来自: 中国浙江衢州
很喜欢这车~~~
bunny 元老 Fans 发消息
发表于 09-3-5 13:35:42 |显示全部楼层 来自: 加拿大
。。。不断地出,看来我要增强自身防御力,抵住诱惑!
kevin88 金牌 Fans 发消息
发表于 09-3-8 10:03:00 |显示全部楼层 来自: 中国广东深圳
几时上市,得个看字
