ego 超级元老 发消息
发表于 09-1-18 01:48:32 |显示全部楼层 来自: 中国广东广州
Novak’s powerful Havoc 3S Brushless/Brush ESC (#1733) is based on the Havoc Sport ESC, which is available with the Havoc Sport Sensored Brushless System (#3038) and Havoc Spec Brushless Systems (#3033 - #3036). The Havoc 3S has the ability to run on either two or three-cell Li-Po batteries, which the speed control automatically detects through Novak’s auto-detect software. This feature allows users to run a wider range of batteries and – for the speed-hungry racers – bestows the Havoc 3S with even more speed than the original 2S Li-Po Havoc Sport ESC. The Havoc 3S’s small footprint and low cost make it a perfect complement for1/10-scale off-road and on-road vehicles, such as theTraxxas’® Slash Pro 2WD Short Course Truck™, HPI’s® E-Firestorm 2WD 1/10th Stadium Truck™, Kyosho’s® LAZER ZX-5 SP™. Additionally, the Havoc 3S contains one of the strongest BECs for sport applications and includes nine adjustable parameters to fine-tune brake and throttle response.
CUTTING EDGE CUSTOMIZATION
For those interested in fine tuning, the Havoc 3S Brushless/Brush ESC offers a simple interface, making the system completely programmable with vast customization opportunities. One parameter, in particular, is Novak’s Throttle Curve that gives drivers the ability to experiment with two throttle responses – Linear and Expo – which range between a direct-throttle response to a smoother, more controlled low-end power delivery. In addition, the Havoc’s Brake Frequency adjustment contains seven degrees of adjustability from a smooth and controllable brake to a more abrupt and grabbier feel. Moreover, Novak has also built into the ESC a Li-Po Cut-Off Circuitry feature, which prevents the batteries from going below the critical safety voltage level. For further racing opportunities, Novak installed a Reverse Disable feature to turn the Havoc 3S into a forward-only brushless system for club-level racing.
Features :
  • Fully programmable, user-friendly interface with nine adjustable parameters: Minimum Brake (10 settings from 0-27%), Drag Brake (10 settings from 0-27%), Dead Band (5 settings from 2-6%), Minimum Drive (5 settings from 1-5%), Throttle Curve (Linear and Expo), Brake Frequency* (7 settings from 1-8 kHz), Reverse*, Motor Rotation* and Li-Po Cut-Off
  • Novak’s One-Touch Set-Up™ for quick, easy transmitter setup
  • Novak’s Smart Braking II™ enables users to “shift” from forward to reverse
  • Water-resistant case with gasket seal
  • Sensor-based for excellent braking and low-speed driveability
  • Auto Detect Brushed Motor Mode
  • Locked Rotor Detection and Thermal Overload Protection
  • Meets RoHS compliance and includes 120-Day Warranty
  • Designed and assembled by Novak in Irvine, California, using globally-sourced components
Spec :
  • Input Voltage: 2-3S Li-Po cells or 4-9 NiMH cells (1.2V/cell)
  • ESC Footprint: 1.18” x 1.54” (30.0 x 39.1 mm)
  • ESC Weight (without wires): 1.50 oz. (42.6 g)
  • Design: Sensor-based
  • Motor Limit (brushless): 8.5-turn Novak 540-size sensored motor
  • Motor Limit (brushed): 27-turn for 540-size motor / 12-turn for 550-size motor
  • On-Resistance (brushless): 0.0012 ohms @ 25°C trans. temp.
  • BEC: 6.0 volts DC / 1.5 amps
  • Rated Current: 120 Amps @ 25°C trans. temp.
  • Braking Current: 120 Amps @ 25°C trans. temp.
  • Status LEDs: 4
  • Voltage Cut-Off: 6.25V (when Li-Poly Cut-Off Circuitry is enabled)
  • Power Wires: 14G Super-Flex Copper-Strand Silicone Wire
