ego 超级元老 发消息
发表于 09-1-12 14:09:04 |显示全部楼层 来自: 中国广东广州
Kyosho 将于 2009年2月推出新的SPADA小油车,使用Mini Cooper S车壳,Spada车系推出也有一定时间,09年Kyosho推出新Spada车款,以保持新鲜感,但现在看Kyosho给出的资料,09 Spada车架部分好像没太多惊喜。
“09 Shirio engines” that had stricken close to home to the world was installed in Mini-inferno 09, and installed in “Spada 09L” that gave long making the wheelbase about 24mm based on the chassis of Spada 09 and was reborn. To make use of the power, a power train and an efficient suspension at 4WD+2 velocity A/T are turned on. An excellent running does and to enjoy it, the devoted chassis design is carried out the simplicity Iz best a difficult unnecessary setting it. For years..race..experience..make the best use of..knowhow..a lot..setting..free..possible. Exactly even if you choose as the introduction to the GP car in addition as Second car. Moreover, it is possible to enjoy it by reproducing of the body form real and adopting the mule tire for the race where the real car feeling overflows.
  • Special chassis that enjoys 1/10 scale 09 engine touring car race.
  • Racing performance of excellence by two belt drive 4WD.
  • Two velocity A/T unit is equipped normally.
  • The Rear is a standard ball differential.
  • 3mm main chassis made of thickness aluminum that boasts of high rigidity, strength, and heat radiation.
  • Enough running time is secured in 38cc fuel tank.
  • Authorized by the vehicle manufacturer, and form a full scale and details.
  • The servo of the normal size can be used.
  • Brake unit of V-ONE equal series.
  • Attachment for receiver ..AAA battery box with BEC connector…
  • The nickel metal hydride battery packing for Rx of Mini-inferno 09 can be used.
  • 14 full bearing specifications in total.
  • The mule tire that realizes the scale feeling by the high grip type is adopted.
KEVIN 论坛元老 发消息
发表于 09-1-14 20:56:57 |显示全部楼层 来自: 中国北京
漂亮漂亮 :em02:
我为模狂 终极 Fans 发消息
发表于 09-1-15 19:23:56 |显示全部楼层 来自: 中国江西
不错不错。
发表于 09-2-20 20:30:47 |显示全部楼层 来自: 中国广东广州
