用了新油 Nitro-X
查看: 15103|回复: 61| [复制链接]
kenfire128 元老 Fans 发消息
发表于 09-1-18 23:25:26 |显示全部楼层 来自: 中国广东广州
很暴力,大家都这么说..............
Kitracer 高级 Fans 发消息
发表于 09-2-9 13:58:26 |显示全部楼层 来自: 中国香港
Thank you for all support using Nitro-X.
Top 14 out of 15 all used Nitro-X at 2009年发财杯.
1st, 2nd, 3rd, 5th, 6th to 10th A main and B main 1st, 2nd , 3rd , 4th and 5th
and
TQ
Also D main 1st.
and rest of the users that used Nitro-X. Thank you again for the great comments
发表于 09-2-9 14:03:07 |显示全部楼层 来自: 中国澳门
Nitro-X 新油好劲 好爆
荣耀的小牛 终极 Fans 发消息
发表于 09-2-9 18:38:08 |显示全部楼层 来自: 中国广东阳江
发财杯也用了 的确很不错 以后打算就用这个油了
马拉仔 超级元老 发消息
发表于 09-2-10 02:27:04 |显示全部楼层 来自: 中国广东广州
hey kitracer, may i know what is the lubrication percentage for nitro-X 25% car fuel ?
马拉仔 超级元老 发消息
发表于 09-2-10 02:29:50 |显示全部楼层 来自: 中国广东广州
1 more question......... a new blend fuel can stay fresh for how many days ? your advise will be much appreciated.....
发表于 09-2-10 10:58:56 |显示全部楼层 来自: 中国香港
马拉仔 发表于 09-2-10 02:27
approx 11%, why do you need to know?
After you finish the tank, you can take your engine apart and use a piece of tissue paper and wipe the crankcase. Then you will see some thin oil but very clean on that tissue paper. That's what I call good quality  oil!
If there is no oil left, you have run too hot and may be already over heated the engine.
发表于 09-2-10 11:05:19 |显示全部楼层 来自: 中国香港
马拉仔 发表于 09-2-10 02:29
It is hard to say depends on how well you Store the Fuel.
If you put the fuel in a dark , cool and dry place, it can stay fresh for over 1 year. If you put in back of your car, may be less than 3 months.
With our Nitro-X fuel, we use a very good mechanical seal cap on our bottles which means no form or rubber seal that will leak over short period of time. You can step on our empty bottle and even the air will stay inside the bottle without leak... not bad right!
It takes a lot of effort to make a good fuel and it takes a lot more effort( that people dont know)  to make sure it stay as a good fuel.
马拉仔 超级元老 发消息
发表于 09-2-10 11:51:00 |显示全部楼层 来自: 中国广东广州
After you finish the tank, you can take your engine apart and use a piece of tissue paper and wipe the crankcase. Then you will see some thin oil but very c ...
Kitracer 发表于 09-2-10 10:58
ic...as i know every brand has different percentage of lubrication on their fuel... 11% is good enough...i need to know that because im not a racer, i need some fuel that have high lubrication and linear power for my engine and last long... thank you for ur information...
马拉仔 超级元老 发消息
发表于 09-2-10 11:51:50 |显示全部楼层 来自: 中国广东广州
If you put the fuel in a dark , cool and dry place, it can stay fresh for over 1 year. If you put in back of your car, may be less than  ...
Kitracer 发表于 09-2-10 11:05
ok thanks alot for information....
