Associated Nitro TC3 Plus RTR R/C Car (2-Speed) Side-exhaust manifold and pipe Two-speed transmission Pre-glued high-grip treaded racing tires with foam inserts Associated Electrics radio system with Steering trim, Throttle trim, Throttle ATV high, Throttle ATV low, Steering dual rate High-performance .15-size 90-degrees-port ABC engine from Associated Electrics. Ball bearings Protective front bumper, composite shocks, adjustable body mounts, quick-fill fuel tank Pivot ball type suspension with easily adjustable caster, camber and toe-in. Interchangeable front and rear hub carriers Two painted body schemes to choose from 8-spoked chrome wheels Rechargeable glow igniter and fuel filler bottle included $329.99 值吗? [em40] |
