nivea 金牌 Fans 发消息
发表于 08-12-8 21:22:08 |显示全部楼层 来自: 中国广东广州
京商的SPADA 小油车系列有新产品,搭载有SIRIO 09 引擎,加长24mm的底盘,SPADA的性能有了进一步提升,再加上日产的March车壳,外型非常可爱。
Features :
* Chassis designed specifically for 1/10, 09-size engine scale touring car racing.
* 2-belt drive 4WD delivers excellent racing performance.
* Equipped with 2-speed A/T unit as standard.
* Features rear ball differential.
* 3mm thick Aluminum delivers a high rigidity and strengthened main chassis.
* 38cc fuel tank provides longer run time.
* Design officially approved by the manufacturer for accuracy in scale form and detail.
* Standard size servos can be used.
* Uses same brake unit as the V-ONE Series models.
* Includes AAA-size battery box with BEC connector for the receiver.
* Compatible with the Ni-MH battery pack for the Mini-Inferno 09 receiver.
* Includes 14 ball bearings in full bearing specifications.
* Front & Rear is fitted with high-grip rubber tires that add to scale appearance.
* Simply attach the officially approved NISMO die-cut decals after painting the body in a single-color to complete. You can even recreate the atmosphere of the March Cup by attaching your favorite racing number.
Rigid front axle greatly contributes to driving stability and supports rubber tire performance.
Newly designed rear axle suspension moves the axle mount with suspension stroke for superior control characteristics.
luckjingjing 论坛元老 发消息
发表于 08-12-8 23:48:19 |显示全部楼层 来自: 中国广东佛山
感觉不错啊...顶一个
发表于 08-12-8 23:56:35 |显示全部楼层 来自: 中国广东广州
a27099596 RC 新手 发消息
发表于 08-12-13 11:41:27 |显示全部楼层 来自: 中国四川成都
挺好看的
不错 不错 啊 呵呵
老顽童 元老 Fans 发消息
发表于 08-12-13 11:58:53 |显示全部楼层 来自: 中国北京
挺好看的!!!
channelchen 中级 Fans 发消息
发表于 08-12-15 00:30:10 |显示全部楼层 来自: 中国广东
大概多少钱啊?~~~
疯狂活塞 超级元老 发消息
发表于 08-12-17 18:36:26 |显示全部楼层 来自: 中国上海
原帖由 shuaizaibai 于 2008-12-8 11:56 PM 发表
想知道实际比例是多少,能不能用M车壳呢?或者1:10的电车壳!
这车是1:12的,只不过是四驱加发动机
