[电子设备] LRP新产品 Quadra-Pro 充电器
查看: 2113|回复: 3| [复制链接]
nivea 金牌 Fans 发消息
发表于 08-12-2 22:24:03 |显示全部楼层 来自: 中国广东广州
LRP新充电器Quadra Pro, 小型、多功能的合成充电器!
带有变压器,输入电压可在100-240V,全球通用。这款充电器的菜单特征和LRP的当家充电器Pulsar差不多,简单易用,可对NiMH, NiCd, LiPo 和 LiFePo 电池使用!还带放电功能和循环模式!
CHARGE
NIMH – LIPO – LIFEPO – NICD
Adjustable fast charge from 0.1 to 5.0A: 1-14 cells NiMH/NiCd with adjustable Delta-Peak detection, 1-5 cell LiPo/LiFePo with automatic cut-off
Autostart Delta-Timer and Partial Charge Mode for maximum comfort and longest lifetime
DISCHARGE
Adjustable discharge current and discharge cut-off voltage
CYCLE
Automatic Cycling Mode (Discharge – Charge – Discharge) for perfect conditioning of your batteries
Microprocessor controlled: Fully adjustable for perfect operation, maximum performance and highest safety Precision adjustment of all parameters (NiMH-NiCd-LiPo-LiFePo / Charge Current / Trickle Current / Discharge Current / Discharge Cut-Off Voltage / Delta-Peak) input and output safety against overload, reverse polarity and short-circuit Integrated AC power supply, useable worldwide with 100-240V. DC input (11-15V) for use with car batteries for maximum flexibility Intuitive menu structure known from Pulsar range of chargers 3 factory pre-set profiles which can be customised and saved in memory Includes all input (AC + DC) and output cables and connectors
tonyshan007 论坛元老 发消息
发表于 08-12-2 23:16:46 |显示全部楼层 来自: 中国辽宁沈阳
一定价钱不菲  但是能冲LIPO  这个好  就是不知道能不能平衡
DYGM 超级元老 发消息
发表于 08-12-3 12:46:52 |显示全部楼层 来自: 中国北京
看样子应该不带平衡充功能,需要外接平衡器……
Himalaya 超级元老 发消息
发表于 08-12-3 12:58:22 |显示全部楼层 来自: 中国北京
原帖由 DYGM 于 2008-12-3 12:46 发表
嗯,小小有点不合时宜了,尤其作为新推出的产品。
最大只能 5S Li ?专配 Losi Xcelorin ?
