[电子设备] 【几只好强的舵机……】
查看: 2383|回复: 2| [复制链接]
DYGM 超级元老 发消息
发表于 08-10-27 10:38:08 |显示全部楼层 来自: 中国北京
前些时间搜罗了些即将上市的舵机,看似非常的强大…… :em21:
【Hitec RCD】
HS-7950TG (7955的更大力版本?)
Detailed Specifications
Motor Type:Coreless
Bearing Type:Dual
Speed:.15
EnglishMetric
Torque:403(29Kg)
Detailed Feature DescriptionsG2 Digital Circuit
Titanium Gear Train (MK first gear)
Ultra Performance Coreless Motor
Heatsink Case
Hardened steel gear pins Supported by Axial Brass Bushings
(8) O-Rings for Water/Dust/Fuel protection
Dual Ball Bearing Supported Output Shaft
Programmable Features Include:
    Dead Band Width Direction of Rotation Speed of Rotation (slower) End Points Neutral Points Fail Safe On/Off Fail Safe Point Resolution* (default is high resolution)
  • Overload Protection* (default is off)
*These features are only programmable with the HFP-20, HPP-20 or HPP-21 programmers.
HS-7940TG (7955的超快速版本?)
Motor Type:Coreless
Bearing Type:Dual
Speed:.07
EnglishMetric
Torque:182 in/oz
Detailed Feature DescriptionsG2 Digital Circuit Titanium Gear Train (MK first gear) Ultra Performance Coreless Motor Heatsink Case (8) O-Rings for Water/Dust/Fuel protection Dual Ball Bearing Supported Output Shaft Programable Features Include:
  • Dead Band Width
  • Direction of Rotation
  • Speed of Rotation (slower)
  • End Points
  • Neutral Points
  • Fail Safe On/Off
  • Fail Safe Point
  • Resolution* (default is high resolution)
*These features are only programable with the HFP-20, HPP-20 or HPP-21 programmers.
【JR】
DS8711 HV (7.4V Li电高压舵机,全铝外壳,超大力……)
DS8711HV High Voltage Ultra Torque Servo
Overview
The 8711HV delivers unheard of power through a new SuperSteel gear train and does it all on a 2S LiPo pack -- without a regulator!
Add its rugged new aluminum case, high voltage motor, legendary JR quality and true, zero-deadband precision--plus its blistering, 0.12 second speed--and the 8711HV represents a whole new level of big model servo performance.
Key Features
  • Rugged new aluminum case
  • JR® SuperSteel™ gears for high precision, long wear
  • Exclusive motor designed for high voltage applications
  • Outstanding precision combined with outlandish performance
Specs
  Size Category: Standard
  Type: Digital
  Application: Giant Scale Aircraft
Torque: 480 oz/in (2S Li-Po) (34.5Kg)
  Speed: .12 sec/60° (2S Li-Po)
  Dimensions (WxLxH): .82" x 1.58" x 1.57"
  Weight: 2.6 oz
  Bushing Or Bearing: Bearing
  Bearing: Dual
  Motor Type: Coreless
  Connector Type: JR
  Gear Type: Metal
  Gear Material: SuperSteel™
  Voltage: 7.4V (2S Li-Po)
  Deadband: Less than .001ms
DS8717 HV (7.4V Li电高压舵机,全铝外壳,超快速……)
Overview
With its new aluminum case, SuperSteel gears, a high voltage motor and improved electronics, the 8717 takes helicopter servos to a whole new galaxy of performance.
Plus it maitains JR's legendary reliability and unmatched, true zero-deadband precision.
Key Features
Specs
  Type: Digital
  Application: 50 size and larger helis
  Torque: 230 oz/in (2S Li-Po)
  Speed: .06 sec/60°
  Weight: 2.6 oz
  Bearing: Dual
  Connector Type: JR
  Gear Type: Metal
:em21: :em21: :em21: ……
看似太强大了,不知道为什么,JR的都是飞行用的呢……
上张JR的图图:
8711:
8717:
[ 本帖最后由 DYGM 于 2008-10-27 10:42 AM 编辑 ]
遥控大猫 超级元老 发消息
发表于 08-10-27 10:48:13 |显示全部楼层 来自: 中国北京
舵机扛得住锂电 接收机不行啊...还要单独接线 很烦
发表于 08-10-27 11:12:56 |显示全部楼层 来自: 中国广东东莞
回复 2# 的帖子
Spektrum 2.4G 那些接收是可直接 2S 锂电!
我的DX-3R 也准备这样!
