Tamiya - F103 15th Anniversary Chassis Kit
Light weight simple chassis constitution the F103 chassis which gathers support with the sharp running. The limited model which commemorates that birth 15th anniversary is appearance. 3.2mm thick [rowa] of new adoption, in 1.5mm thick upper carbon plate logograph pad printing. The aluminum servo mount renovates design, the aluminum make upper deck post, private part such as T bave ridge and the teflon make friction plate which modify the material is full load.
The aluminum diff. housing, the height adjustment type aluminum motor mount, the TRF damper, it equips also OP part such as aluminum turn buckle shaft and carbon shaft. * Full bearing specification.
