无间道 论坛元老 发消息
发表于 08-9-11 22:21:21 |显示全部楼层 来自: 中国广东广州
Baja 5B/Uses oversized bearings for more increased durability.
This Heavy Duty Aluminum Pinion/Clutch Mount is a machined alloy option part for HPI Baja 1/5th scale vehicles. This is an authentic HPI bolt-in upgrade part that is precision built to the exact factory specifications for a perfect fit. Heavy duty aluminum construction helps give the pinion gear and clutch extra support for improved durability and longer gear life. The mount comes with two rubber sealed ball bearings (B097) that have a larger outside diameter for high efficiency and long life. Machined from billet aluminum and gunmetal anodized for a custom look. This upgrade part replaces the stock nylon mount (#85436).
Source : HPI
GASRC 论坛元老 发消息
发表于 08-9-12 02:31:20 |显示全部楼层 来自: 中国云南西双版纳傣族自治州
I do not know English please translation Thank you
suduogou RC 新手 发消息
发表于 08-9-12 08:59:19 |显示全部楼层 来自: 中国重庆
又有人放毒啊,我向环境署检举你!不过....真的太漂亮了......
baukran 超级元老 发消息
发表于 08-9-12 09:57:59 |显示全部楼层 来自: 中国北京
like啊~~~~~~~~~闪~
WILLY.CHEN777 终极 Fans 发消息
发表于 08-9-12 12:19:55 |显示全部楼层 来自: 中国江苏苏州
發個自己做的離合器固定座,還沒做表面處理.
請各位同好提點意見!
