新品 : HPI BAJA 5T RTR
查看: 20524|回复: 73| [复制链接]
NitroChicken 超级元老 发消息
发表于 08-9-5 10:49:35 |显示全部楼层 来自: 中国广东佛山
Baja 5T Features标配:
Baja 5T-1 Truck Body
Tough 2mm polycarbonate Baja 5T-1 desert truck body. Pre-painted, pre-trimmed with body post holes, pre-applied racing decals and clear tinted windows.
Truck Body Mounts
Tough nylon construction and 8 mounting points keep the truck body securely mounted, fully adjustable design for compatibility.
Molded Rear Spoiler
Molded nylon rear spoiler for stable handling. Molded nylon rear body brace for body protection, includes provisions for optional rear LED tail lights.
Fuelie 26 Engine (26cc)
26cc engine for more power, more torque, and more speed than 23cc engines. Equipped with a convenient pullstarter for quick and easy starting. A high capacity dual-element air filter keeps the engine running clean even in grueling off-road conditions, quick-change design for easy maintenance. Air cooled with built-in fan for consistent running temperatures. Fully adjustable carburetor with primer and kill switch. Now constructed using Torx screws for extra durability and easier maintenance, Torx T-27 wrench included.
Gasoline Powered
Gasoline powered for low-cost operation compared to nitro fuel, easier to tune and more consistent than nitro engines. More than 30 minutes of run-time per tank.
Ready-to-Run
The Baja 5T comes pre-built from the factory to precise build tolerances. Normal build-time for a vehicle like the Baja 5T is around 8 hours, but you can hit the track in just a few minutes, reassured by the knowledge that your truck was prepared by trained assembly specialists.
Aluminum Alloy Diff Case
For increased drivetrain durability and extended time between maintenance.
VVC/HD Shock Set
Oil-filled coilover shock set with large diameter shock shafts for increased durability, 16 hole rear piston with sealing ring for consistent damping, fully adjustable design for tuning options.
Front Skid Plate Bumper
Adjustable skid plate front bumper protects the truck on big jumps, now with 4 headlights for realistic Trophy Truck looks.
Dirt Guards
New side guards deflect dirt and debris away from the chassis. The engine also receives dirt guards on both sides for extra protection.
Extended Roll Cage
Extra bracing for durability, extended upper roll cage for spark plug protection.
Outlaw Truck Wheels
8-hole design, tough nylon construction, authentic bead-locks for durability and tuning options.
Desert Buster Tires
Large diameter truck tires for realistic looks. Heavy duty rubber compound and thicker carcass for extra durability.
Heavy Duty Inner Foam
Special heavy duty rear inner foam inserts for extra durability and extended tire life.
Revised Gearing
New 19T transmission top gear adapts the drive ratio for quick acceleration and high top speed when using truck tires.
High Flow Muffler
Large capacity design, tuned for increased horsepower.
SFL-10MG2 Metal Gear Steering Servo
Tough metal final gears for extra durability and reliable steering. Ball bearing equipped and water resistant. This oversized steering servo has high torque specs, making it a perfect match for the Baja 5T.
Heavy Duty Beadlocks
Reinforced design increases durability of the wheels and tires. Beadlocks allow the removal and replacement of individual parts of the wheels and tires for maintenance.
8000 RPM Clutch
Lightweight clutch and heavy duty spring launches the Baja 5T at higher RPM for more punch off the line.
Anodized Aluminum Parts
Black anodized 4mm 6061-T6 aircraft grade extruded and CNC milled chassis, orange and gunmetal anodized alloy parts give the Baja 5T an aggressive look.
Double Wishbone Suspension
Full double wishbone front and rear suspension to soak up off-road bumps and jumps. Consistent geometry throughout the full stroke of the suspension movement for precise handling.
Adjustable Suspension
Turnbuckles for quick and easy adjustment of toe-in. Fully adjustable camber and caster for tuning the handling to a wide variety of conditions. High quality nylon is used throughout the suspension for protection from crash damage.
High Quality Radio Equipment
The Baja 5T comes ready-to-run with a high quality 3-channel FM radio with excellent range, a high torque metal-gear steering servo, failsafe equipped receiver, throttle servo and a 3000 mAh rechargeable Ni-MH receiver battery pack. The critical electronics are enclosed in a water resistant compartment to shield them from the elements.
All-Metal Transmission Gears
All-metal transmission gears for incredible drivetrain durability, even in difficult off-road conditions with powerful engines like the Fuelie 26.
Full Ball Bearings
23 precision metal ball bearings for efficiency, durability, and extended maintenance intervals.
Front & Rear Sway Bars
Sway bars are used on the front and rear suspension for precise handling and stable steering feel.
Modified Rear Shock Tower Brace
Relocates shocks for increased rear suspension travel for stable performance on rough surfaces and soft landings over jumps.
Heavy Duty Rear Dogbones
Metal construction with rubber dirt boots for extra durability with high horsepower engines like the Fuelie 26.
Disc Brake System
Braking is controlled by a vented steel/aluminum hybrid brake rotor and semi-metallic brake pads for smooth and consistent stopping power.
Video
http://www.youtube.com/watch?v=STwrSLMJPc4
[ 本帖最后由 NitroChicken 于 2008-9-5 10:50 AM 编辑 ]
小程 长老 Fans 发消息
发表于 08-9-5 11:07:36 |显示全部楼层 来自: 中国辽宁大连
国产的这些车商别仿5b了,直接仿5T吧,呵呵
yl810409 元老 Fans 发消息
发表于 08-9-5 11:24:17 |显示全部楼层 来自: 中国广东惠州
好看 :em07:
yuzhanwen 论坛元老 发消息
发表于 08-9-5 12:17:30 |显示全部楼层 来自: 中国广东珠海
我日,,,,我的下个目标还没有实现.就5T出来了...... :em07:
呼哧 论坛元老 发消息
发表于 08-9-5 12:20:32 |显示全部楼层 来自: 中国江苏无锡
钱啊钱啊   还让我们消停吗
lhh 超级元老 发消息
发表于 08-9-5 12:35:45 |显示全部楼层 来自: 中国广东梅州
:em07:
xuanyue 终极 Fans 发消息
发表于 08-9-5 13:26:14 |显示全部楼层 来自: 中国广东深圳
帅呀,太诱人了~~~
★厦门大马力★ 金牌 Fans 发消息
发表于 08-9-5 13:36:38 |显示全部楼层 来自: 中国福建厦门
5T来势汹汹,看来又要毒倒不少人了。。
开始喜欢玩车 高级 Fans 发消息
发表于 08-9-5 15:52:45 |显示全部楼层 来自: 中国上海
价格估计也在8000多了......艾
中意 论坛元老 发消息
发表于 08-9-5 16:37:03 |显示全部楼层 来自: 中国浙江金华
卡车!!!
:em07: :em07:
