kiro 金牌 Fans 发消息
发表于 08-7-9 21:41:01 |显示全部楼层 来自: 中国广东广州
Serpent - 960 Aluminium Radio Plate Support
Aluminium radio plate support for the Serpent 960, together with a 50g brass weight and fasteners.
Serpent is pleased to announce the release of this aluminium radio plate support with brass weight. Similar in structure to the previous aluminium bracket, this version has been modified to accept the brass weight and will come as standard in future 960-08 kits.
The accompanying brass weight adds 50 grams to very centre of the car and is mounted as low as possible in this area so as not to adversely affect the centre of gravity. Similar in concept to the previously released brass battery holder, this system gives a more neutral handling characteristic than that of the battery holder yet has the same benefits.
kiro 金牌 Fans 发消息
发表于 08-7-9 21:41:26 |显示全部楼层 来自: 中国广东广州
Serpent - 960 V3 Rear Shock Tower
Serpent 960-08 3.5mm thick carbon fibre rear shock tower.
Serpent is pleased to announce the release of this new shock tower for the rear of the Serpent 960. Made from 3.5mm thick carbon fibre, the new shock tower features a 2nd, higher mounting hole for the centring pin. This hole allows for the rear body mount to be set at its highest setting, while still being able to be centred. Some new low body shells work best when they are raised at the rear and this new shock tower facilitates that. This part will come as standard in future 960-08 kits.
falpsp 终极 Fans 发消息
发表于 08-7-9 23:22:19 |显示全部楼层 来自: 中国四川成都
漂亮!!!!!!!!!
