leoleo 超级元老 发消息
发表于 08-5-10 23:58:16 |显示全部楼层 来自: 中国广西南宁
很漂亮的电卡,好象是2WD的竞速卡车,而且是号称无刷READY的。看起来象是应对HPI的E-FIRESTORM推出的。不过TRAXXAS这台SLASH的造型比较仿真,行走姿态也很漂亮~~和E-FIRESTORM都一样拥有飞快的速度~~
SLASH的视频:
http://www.traxxas.com/products/promo/5805_promo.htm
Brushless Ready
The Traxxas Slash is built for extreme Velineon™ brushless horsepower (sold separately). Simply bolt it in and 7-cell speed jumps to 40+mph. Add 11.1V LiPo batteries and you have the potential to double your speed. Bigger roosts and longer hang-time are right at your fingertips. The included steel transmission gears, full ball bearings, and high-quality metal turnbuckle links are the winning setup for brushless durability. The factory-installed planetary differential is Traxxas-tough with hardened steel gears that never need adjusting! Perfect for long-lasting, all-day fun. Accessory battery hold downs are available for use with large capacity Lipo battery packs* that can extend speed and run time. Compare the durability and features to others and you’ll see that only Traxxas makes them truly brushless ready.
  • Titan® 12-Turn 550 modified motor
  • XL-5 waterproof electronic speed control
  • Water-sealed receiver box and steering servo
  • Metal gear Magnum 272™ transmission
  • Revo®-spec torque-control™ slipper clutch
  • Adjustable steel turnbuckles with captured rod ends
  • Scale ProGraphix® truck body
  • The tires are mounted on satin-finish 2.2" Slash wheels
  • Powder coated progressive rate white springs
  • The ESC and receiver mounted directly to chassis
  • Included optional 23-tooth pinion gear
leoleo 超级元老 发消息
发表于 08-5-10 23:59:28 |显示全部楼层 来自: 中国广西南宁
Intense Short-Course Racing Action!
The new Traxxas Slash Short-Course Race Truck puts you in the drivers seat for intense fender-to-fender, high-flying off-road action. The full-scale Short-Course Race Trucks embody the spirit of Traxxas R/C with their extreme 800+ horsepower racing engines full-throttle, dirt-roosting power slides, giant suspension travel, and Supercross-style big-air jumps. The Traxxas Slash brings all the action home so you can experience the high-speed head-to-head competition at the track or in your own backyard. The Slash was inspired by the CORR™ (Championship Off-road Racing) Pro-2™ class. The Pro-2 class specifies rear-wheel drive trucks purpose built to fly over jumps and rip full-throttle through the turns. The Traxxas Slash hangs it out for an all new way to challenge your driving skills. The 4-wheel independent suspension has been carefully tuned to replicate the Pro-2 driving and handling experience as closely as possible. The scale appearing tires provide just the right amount of bite and thick, blinding clouds of dirt roost.
Sealed Electronics Extend Your Driving Fun
Traxxas shocked enthusiasts with the release of our exclusive watertight, sealed electronics in the E-Maxx that provided the freedom to drive where you want to drive through water, mud, snow, and other wet-running conditions that wouldn’t have been possible before. Now the Traxxas Slash is only the second Ready-To-Race model ever to come equipped with this brand new technology. The new XL-5 electronic speed control and the mini receiver are sealed against the elements giving you the freedom go places you might not have though possible. It opens up a whole new world of adventure and fun. Wet muddy tracks are no problem for the Slash. The battery compartment makes it easy to install batteries and the clever design makes it quickly adaptable for either 6 or 7-cell running (hump packs or stick packs).
Modified Muscle
The Titan 12T 550 modified motor is designed for incredible mod-motor power output with virtually maintenance-free operation, and long-lasting performance. The Titan 12T 550 motor’s integrated cooling fan pulls cool air through the motor to keep temperatures down. Airflow is routed through vent tunnels molded in the motor plate. A cooler running motor equates to faster speeds, longer runtime, and extended motor life. The XL-5 Electronic Speed Control offers high current handling, EZ-Set® one-button setup, and smooth high-frequency control. Three drive profiles, thermal shutdown protection, gold-plated connectors, and incredibly low resistance are all features you might expect to only be available on an expensive replacement ESC. As today’s batteries store more and more energy inside their cells, traditional battery connectors could no longer keep up. The included Traxxas High-Current Connector opens the door for unrestricted current flow.
Training Mode
Traxxas’ exclusive patent-pending Training Mode™ let’s everyone get in on the racing action. Just press a button to limit full-throttle power to 50%. This allows young or new drivers to safely develop their control skills before unlocking full power to the mighty Titan 12T motor. The Slash is perfect for drivers at all experience levels. Training mode even makes it easy to hand the transmitter over to your friends who have never driven a radio controlled truck before.
发表于 08-5-11 00:07:37 |显示全部楼层 来自: 中国山东青岛
Himalaya 超级元老 发消息
发表于 08-5-11 00:29:05 |显示全部楼层 来自: 中国北京
比 E-REVO 早一点发布,上个月已经作为标准产品列在网站上了,而E-REVO到现在还没有。
设计似乎找不到前世,不像Truggy也不像通常的 2WD 电卡,Traxxas叫它“短途赛卡”,还没搞懂含义。
感觉这类玩意应该由 Tamiya 推出才对。
lhchc 金牌 Fans 发消息
发表于 08-5-11 01:09:14 |显示全部楼层 来自: 中国四川成都
原帖由 Himalaya 于 2008-5-11 12:29 AM 发表
如果是TAMIYA生产的话 估计是硬壳版本 买来放他几年又是一代经典了
不过TRAXXAS的当家产品还算REVO和MAXX
leoleo 超级元老 发消息
发表于 08-5-11 01:27:24 |显示全部楼层 来自: 中国广西南宁
你想说的是CC01那种车吗?
可是我觉得还是不大一样~~
SLASH的摆臂还是比较象传统卡车,虽然车壳比较象拉力、平跑~~
corden 论坛元老 发消息
发表于 08-5-11 03:22:12 |显示全部楼层 来自: 中国云南昆明
出了几月了吧~!!!
iamccie 超级元老 发消息
发表于 08-5-11 08:35:00 |显示全部楼层 来自: 中国北京
这车看着怎么有点怪怪的哦
CIH 论坛元老 发消息
发表于 08-5-11 09:07:50 |显示全部楼层 来自: 中国浙江宁波
这个车壳我喜欢 比较像真车
gaoyajun 论坛元老 发消息
发表于 08-5-11 09:26:21 |显示全部楼层 来自: 中国新疆乌鲁木齐
车壳挺不错的 ;P ;P
