http://www.spektrumrc.com/Products/Default.aspx?ProdID=SPM1300
Nitro Telemetry Combo Pack
Overview
It’s a tool that no serious racer will want to do without – a tool that gives you the kind of information that helps you tweak your car for maximum performance. And it's all packaged in one convenient box.
If you’re a serious racer, you’re probably way ahead of us in figuring out Spektrum Telemetry’s benefits. But we’ll list them nonetheless.
There are benefits like engine-saving feedback to help maximize performance while preventing costly failures and rebuilds. And the elimination of dumped rx packs means no more crashes or DNF’s due to battery failure in nitro-powered vehicles.
Besides that, Spektrum Telemetry’s lap timing helps you analyze the effectiveness of tire and gear selections, suspension tweaks, etc. Plus it backs up race organizers’ lap counting systems.
Add its RPM sensing to give you a handle on your car’s actual speed, plus the Quality of Signal feature to monitor RF link strength, and you’ve got the whole package.
| Key Features
- Monitors Temperature to maximize performance and eliminate costly re-builds
- Battery voltage display prevents runaway crashes in nitro cars
- RPM display shows top-end speed
- Quality of signal monitors RF link strength
- Lap Counter/Timer helps analyze results of performance tweaks
这是严肃的竟赛者不会想要做无的工具- 给您这信息帮助您扭捏您的汽车为最高性能的工具。并且它所有被包装在一个方便箱子里。如果您是一位严肃的竟赛者, 您大概是方式在我们之前在计算在Spektrum 测距术的好处之外。但我们将列出他们仍然。有好处象引擎挽救反馈帮助最大化表现当防止昂贵的失败和改建。并且被倾销的rx 叠板的排除不意味没有其他崩溃或DNF 的由于电池失败在供给硝基动力的车里。除那以外, Spektrum 测距术的膝部时间帮助您分析轮胎和齿轮选择、悬浮扭动, 等的有效率。正它支持种族组织者的膝部计数系统。增加它的RPM 感觉给您把柄在您的汽车的实际速度, 加上信号特点的质量显示器RF 链接力量, 并且您有整体包裹。 主要特点 显示器温度最大化表现和消灭昂贵的改建电池电压显示防止逃亡崩溃在信号显示器的硝基汽车RPM 显示展示上面结束速度质量RF 链接力量膝部帮助分析表现扭动的结果的Counter/Timer
| Detailed Information
ITEM# | DESCRIPTION | DIMENSION (in) LxWxH | WEIGHT (oz) | TYPE | PARAMETER RANGE | SPM1320 | Handheld Unit | 2.75 x 2.60 x 1.25 | 3.6 (with battery) | 2.4GHz Digital Receiver | n/a | SPM1325 | On-Board Module | 1.08 x .725 x .48 | 0.1 | n/a | n/a | SPM1450 | Head Temparature Sensor | 8.25 wire length | n/a | Thermistor | -35º to 575º F | SPM1452 | RPM Sensor | 6.3 wire length | n/a | Infrared | 0-50,000 rpm | SPM1453 | Lap Counter/Timer Sensor | 6.3 wire length | n/a | Infrared | 0-99 laps/.01 sec. increments | SPM1501 | Sensor Mount Hardware: .21-.26 | 2.36 x .32 x 1.25 | 0.1 | Aluminum | n/a | SPM1502 | Sensor Mount Hardware: .21-.26 | 1.78 x .32 x 1.25 | 0.07 | Aluminum | n/a |
[ 本帖最后由 Panda 于 2008-2-16 09:17 AM 编辑 ] |
