jovi 论坛元老 发消息
发表于 07-12-11 16:01:32 |显示全部楼层 来自: 中国广东广州
作为一个临时的解决办法,做如下操作可以访问RCFANS
  j& z5 R6 I- ]% W% e( Y6 W9 P' b# _5 R4 O; ]: U  J
1 找到系统盘的WINDOWS路径, 一般是 C:\Wndows ,如果系统盘装在D盘 就是 D\Wndows0 E' [' b7 ~+ R5 c
2 打开如 C:\Windows\System32\Drivers\Etc ,可以看到里面有个没有后缀名的文件hosts,点右键
% o6 B5 U& r3 u& c+ k3 在右键弹出菜单里选择“打开”, 选择打开方式, 用写字板或者记事本打开
+ q" {" y6 D- U! h4 _( ~- O" i& s8 p  w4 在打开的HOSTS文件的最后一行按回车,新增一行8 K5 i- \1 N; D3 q9 R4 [! K2 r/ a: x
5 加入“218.16.119.132  bbs.rcfans.com”的字句,结果类似以下的红字部分" h, t6 ~' m/ U. Q- k4 A
& {; K, D9 A2 R! m3 t
# copyright (c) 1993-1999 microsoft corp.2 _/ `7 _7 ]8 d3 a1 L( O
2 X& e8 W3 h( Y) `  W. |- E: e# this is a sample hosts file used by microsoft tcp/ip for windows., @- }" a& i# M7 j; E
#) [$ k& D6 b" C
# this file contains the mappings of ip addresses to host names. each
# m) a: B8 X( j1 m  u0 C# entry should be kept on an individual line. the ip address should
& N. f. i# x. H' n0 f' B2 e0 D# be placed in the first column followed by the corresponding host name.
1 E* u# F$ j3 z" g, b* r8 N) G0 ?# the ip address and the host name should be separated by at least one. S* @; d2 E" {* {3 M
# space.. H1 G3 d6 p/ m; O, ]
$ W; L7 T& \1 U# additionally, comments (such as these) may be inserted on individual
8 h+ C0 J# c+ A: ]  S# lines or following the machine name denoted by a '#' symbol.
: S* ~9 q8 u; B1 @1 |' }#/ k- z. C. U3 Z3 u. S1 b, e& }
# for example:
1 [" v' i' N$ u/ i( T#
: m% F# V9 a1 m  R2 V8 Q( F#      102.54.94.97     rhino.acme.com          # source server
* ]. j  m' G9 l6 a#       38.25.63.10     x.acme.com              # x client host; K- K+ l; D/ l# A2 D9 h2 G! T
1 c9 D4 H# b9 g; T" \127.0.0.1       localhost% g) d* I3 Y7 u+ M% T
61.142.82.2  bbs.rcfans.com
4 [1 e; e' i9 D7 j0 z
* f* G$ M! A) d  U1 K* Q' s: z% N- Z6 保存文件,关掉浏览器,再重新打开浏览器
6 m% |$ ]! w  q( z+ m5 ^7 此时应该能访问RCFANS了+ ^6 q4 C; g9 C: h+ r/ x
3 w# T' u* D4 o* _. I
: R- Y& g& z5 P, k# {9 O2 @
. A: E1 U3 @% y. i" H  e* F3 b) z4 C8 [
( K) U& j& H7 Y, u; C4 y
最近有一些FANS反映论坛的访问比较慢,我们来分区处理一下。 请出现这种情况的FANS,协助论坛完成改善工作。请完成以下操作并跟帖回复您的结果:+ J- {7 ?7 P8 q3 Y1 w
+ Y/ U& D$ |7 V# E0 q: l9 d( c/ E1 点电脑屏幕左下角的“开始” 4 o! _3 K8 y/ S0 T3 X
2 点列表的最后一项“运行”
. d$ ?/ L) F7 D* C1 G3 在小窗口中键入 "cmd" 回车
0 o& M. `# G1 W4 弹出黑色小窗口,在窗口的命令行中键入 "ping bbs.rcfans.com -t" 回车 ; |! K, E" c' B$ G
5 出现如下界面. _" \% x- m' U$ z
. n7 D2 }( W  l5 ~8 j5 U' k
6 请把您得到的IP地址跟帖告诉我,如界面中的218.16.119.132,如果可以请把上面的信息黏贴或截图发表出来,并且告诉我您是网通还是电信的用户 . @2 _  z8 ~% S' D  ]7 q: K
5 I8 {" y$ ^: S; L非常感谢大家对RCFANS 的厚爱
jovi 论坛元老 发消息
发表于 07-12-12 18:12:27 |显示全部楼层 来自: 中国广东广州
作为一个临时的解决办法,做如下操作可以访问RCFANS' h: `7 ?) K- I/ h6 l) x
0 t( W8 B. p7 F: D$ M" b* o; L
1 找到系统盘的WINDOWS路径, 一般是 C:\Wndows ,如果系统盘装在D盘 就是 D\Wndows' G% s2 N; u1 |) C/ ?
2 打开如 C:\Windows\System32\Drivers\Etc ,可以看到里面有个没有后缀名的文件hosts,点右键/ P# R& Q# h% R7 ~, c. _
4 G% U/ |: E5 {# ?" v+ ~/ ^4 在打开的HOSTS文件的最后一行按回车,新增一行' N' f$ L7 b3 y; z: g
6 n; c8 S$ w5 n* h, \) a0 x% m9 A- o* @; \4 [& r4 v
# copyright (c) 1993-1999 microsoft corp.1 Z+ _# X* o9 ?' B# s$ H
- C9 T$ c  U0 [* }, S# this is a sample hosts file used by microsoft tcp/ip for windows.5 Q( Q* z" m$ B  q" y% k) Y
#* i: q  q( y, K3 x
# this file contains the mappings of ip addresses to host names. each# t' g0 @4 C; c/ G% X$ Z
# entry should be kept on an individual line. the ip address should1 k4 b9 a) R3 O9 M
# be placed in the first column followed by the corresponding host name.# [/ ^& b1 a0 Z* n
# the ip address and the host name should be separated by at least one; h  s- A9 f, `2 o, i  D
# space.
+ r# P! h# _5 h- I& g/ M#
! K- b8 [/ {1 a& d/ V/ q# additionally, comments (such as these) may be inserted on individual
) M3 R" I% q6 n# lines or following the machine name denoted by a '#' symbol.
6 u3 D( A3 I8 F5 g#
7 c/ D6 {( u( x& \# for example:* U/ }# B, g4 ]6 i% J3 t
#3 c# ]( y4 @  i/ h
$ R. B2 c7 e" }. `( h, D9 ~#       38.25.63.10     x.acme.com              # x client host! f7 k" o+ @, T; g6 l/ u9 B" z
$ D' a- O( f: [) C' o+ N127.0.0.1       localhost
) p$ T1 m; Y1 m( {/ M8 m+ Q& U# @3 Q218.16.119.132  bbs.rcfans.com
2 ~6 k0 S: }: h8 E8 M8 r5 x9 X/ J; h5 K! |
6 保存文件,关掉浏览器,再重新打开浏览器& E* R  ?  v. a; P0 q9 I/ A1 @
7 此时应该能访问RCFANS了
jovi 论坛元老 发消息
发表于 07-12-12 18:15:19 |显示全部楼层 来自: 中国广东广州
如果发现图片无法显示,或者www.rcfans.com访问不了。可以仿效以上的操作,在218.16.119.132  bbs.rcfans.com后面加入如下行:9 m% d) C5 L1 q5 p
' @) z4 F1 b2 {+ G218.16.119.132  www.rcfans.com. |4 f. F$ J4 c$ v$ ?4 |
218.16.119.132  www.rcfans.net& {4 d- }( b0 X( }, P
218.16.119.132  img.rcfans.com
悠游06 论坛元老 发消息
发表于 07-12-12 18:16:18 |显示全部楼层 来自: 中国江苏苏州
回复 2# 的帖子
哈哈,好几天多有问题了,现在终于又可以好好上了,感谢LZ啊!
SuperStorm 论坛元老 发消息
发表于 07-12-12 23:52:44 |显示全部楼层 来自: 中国广东深圳
不是LZ.是总版主
dunwee 超级元老 发消息
发表于 07-12-13 22:58:00 |显示全部楼层 来自: 中国四川成都
实用型帖子,为了更多FANS看到,人工提升下。。
宁宁 超级元老 发消息
发表于 07-12-13 23:03:48 |显示全部楼层 来自: 中国北京
北京的什么时候出呀  也好慢
itanium 金牌 Fans 发消息
发表于 07-12-14 14:49:44 |显示全部楼层 来自: 中国黑龙江哈尔滨
龙少 超级元老 发消息
发表于 07-12-16 16:19:43 |显示全部楼层 来自: 中国云南西双版纳傣族自治州
ly800608 论坛元老 发消息
发表于 07-12-16 18:39:08 |显示全部楼层 来自: 中国辽宁沈阳
沈阳网通,今天还可以,昨天就很慢了
