5. Reassemble in reverse order. Be sure to fill the shocks with 100% pure silicone shock oil to help prolong the life of the seals. From the factory, the GT-Maxx shocks are filled with 60W shock oil in the front and 50W shock oil in the rear. When adding shock fluid, be sure to allow any air bubbles to escape. 5. 以相反顺序重新组装。请务必用 100% 纯硅油减震器填充减震器,以帮助延长 密封件的使用寿命。出厂时,GT‑Maxx 避震器前部装有 60W 避震油,后部装有 50W 避震油。添加冲击液时,一定要让气泡逸出。 不知道翻译的对不对 |
From the factory, both the differentials are filled with SAE 50,000W viscosity silicone oil. Only use silicone oil in the differentials. Traxxas sells SAE 10,000W, SAE 30,000W, SAE 100,000W, and SAE 500,000W viscosity oil (see your parts list). The differentials have to be removed from the vehicle and disassembled to change/replace oil. 出厂时,两个差速器都填充有 SAE 50,000W 粘度硅油。仅在差速器中使用硅油。 Traxxas 销售 SAE 10,000W、SAE 30,000W、SAE 100,000W 和 SAE 500,000W 粘度油 (请参阅零件清单)。差速器必须从车辆上拆下并拆卸以更换/更换机油。 Torque-biasing center drive unit: The Sledge is equipped with a torque-biasing center drive unit. The drive unit can be rebuilt, but it requires a detailed maintenance procedure and the use of 20MM weight differential oil (part #5040). ‧扭矩偏置中心驱动单元: Sledge 配备扭矩偏置中心驱动单元。可以重建驱动装置, 但需要详细的维护程序和使用 20MM 重量差油(部件号 5040)。 差速的,有点搞不懂 |
