禾寶新車預告 Hyper MTX
查看: 6048|回复: 23| [复制链接]
就会瞎几把摁 元老 Fans 发消息
发表于 22-8-15 15:06:01 来自手机 |显示全部楼层 来自: 中国辽宁
之前纠结了很久七车mt,最后决定买八车继承者但还没动手。我先观望一下这个。总之必须拿下一个侧板!
美美美食家 金牌 Fans 发消息
发表于 22-8-15 23:49:04 来自手机 |显示全部楼层 来自: 中国北京
禾宝的车结实和好玩,整车价格还行就是配件的价格....我玩8sc换个防撞和摆臂就两百受不了了静态了国产车配件便宜一点
单眼皮 金牌 Fans 发消息
发表于 22-8-20 16:51:06 来自手机 |显示全部楼层 来自: 中国河北
按照以往的惯例,应该没有什么大的改进,估计也就是换七车件吧
Bardor RC 新手 发消息
发表于 22-8-26 16:32:27 来自手机 |显示全部楼层 来自: 中国台湾
今天更新
一樣只有一圖
wk68185239 高级 Fans 发消息
发表于 22-8-26 16:36:33 |显示全部楼层 来自: 中国内蒙古呼伦贝尔
盲猜带种差的8车大脚
Bardor RC 新手 发消息
发表于 22-8-26 17:57:41 |显示全部楼层 来自: 中国台湾
有中差啦
Hyper MTXE Monster Truck
[ELECTRIC EQUIPMENT]
Radio: 3-channel 2.4GHz FHSS with dual rate steering and throttle
Hobby Wing 150A ESC/ 4S~6S / Pair XT90 connectors/ Cooling fan/ Program card
Motor: Brushless/ 2000KV/ 4 poles/ Outer Diameter 40mm/ Shaft Diameter 5mm
Servo: 32Kg-cm, 7.4V High Torque & High speed / Coreless Digital / Waterproof
[FEATURES]
Chassis: Havey duty alum 7075 monocoque chassis frame
Ball Bearings: Full set included
All metal transmission gears
Drive: AWD, Heavy duty driveshaft
Front & Rear Differentials: Steel bevel gear/ Anti-leakage differential housing/ Hardened steel cups
Center Differential: Steel bevel gear/ Alum anti-leakage differential housing
Pinion and Ring Gear: 9T/ 29T (MOD 1)
Spur Gear: 36T (MOD 1)
Motor Gear: 15T (MOD 1)
Motor Mount: adjustable
New oil-filled 17mm big bore and long stroke, 4mm diameter shafts
Shock: Height adjustable shock spring perches
New shock piston with 3 x 1.6mm holes / configure option OP-0135 / new reinforced top end and rod end
New shock shaft: special surface treatment improves the shock performance
Suspension: reinforced composite upper arms and lower arms
Front/Rear high torque universal joints with differential outdrive cups
New servo saver & Steering rack & Hard spring
New shock top cap protector with body post
Alum wheel hub and nuts: 17mm Hex/ Alum anti-loose wheel Nut
Wheel Nut option: OP-0090/ OP-0091/ OP-0092
New front and rear shock tower brace
New center roll bar/handle
New alum shocks stiffener plate
Battery Holders: Large capacity box with quick release design
Motor Heatsink with Fan
Body: 1/8 scale painted
Tyres:  182mm Monster Truck Tyres
6 spoke monster wheels, Grey, 17mm Hex
RJr 元老 Fans 发消息
发表于 22-8-26 18:53:31 来自手机 |显示全部楼层 来自: 中国湖北黄石
好车,无脑入
可爱的贪吃猫 长老 Fans 发消息
发表于 22-8-26 19:22:43 来自手机 |显示全部楼层 来自: 中国北京
好车,但可惜配件太贵了赶上竞赛级的车了
不入魔不快活 长老 Fans 发消息
发表于 22-8-27 08:13:05 来自手机 |显示全部楼层 来自: 中国上海
不是就是原7车,稍微改一点。不过禾包大脚车壳真不错。就是件价格太贵了玩不起
发表于 22-8-27 15:16:46 |显示全部楼层 来自: 中国内蒙古呼伦贝尔
看了下老款8车和7车对比一下新的,就是把7车的中间侧板桥换成新规8车的,然后按上以前8车的轮胎,把轮毂涂个新色,换个车壳。。。。但是这个新款的8车强度应该是顶级的,毕竟就是7车的结构换了个大桥
