MP777的最新技术资料 - Gearboxes now have an ''X'' for added strength inside. - Gearboxes now same material as K3 Arms (fragmented carbon) - Longer lower arms - They have moved the lower arms more to the centre - New optional 2mm carbon servo saver plate, new design of the servo saver plate - 2mm lower radioplate (No laydown servos) - Engine & centre diff moved forward a little bit - Chassis will be 2mm bigger (maybe longer/wider?) - Small changes to both shock towers - New longer reinforced upper arms curve (like MBX5) - New 4mm shock shafts, larger shocks (width, length) New caps - New lower servo saver design, steering will be from the outside - New more aerodynamic body ![]() All Information comes from Neo-buggy! [此贴子已经被作者于2004-5-4 13:56:36编辑过] |
