JP 超级元老 发消息
发表于 07-10-20 11:33:40 |显示全部楼层 来自: 中国广东佛山
HPI 新颜色 ~ 橙
26cc 汽油引擎
   高強度狗骨
金屬差速壳
BAJA SS kit帶24KG金屬齒轉向舵機
8000rpm 極力子彈簧
Baja 5B SS Features:
Aluminum tuned pipe*
Increased Power
Front and rear sway bars
Improved handling
Modified rear shock tower brace
Increased rear suspension travel
Heavy duty rear dogbones
Improved durability
Aluminum alloy diff case
Improved durability
VVC/HD shock set
Better handling and improved durability
Fuelie 26S engine
Increased power and torque over 23CC engine
Metal gear steering servo
Increased durability
Clear pre-cut body
Ready for your custom paint
Heavy duty rear beadlocks
8000 rpm clutch
Quick throttle response
*Kit also includes stock muffler for quieter operation
Baja 5B SS Specifications:
Chassis
  • Overall Length: 32 in (817mm)
  • Height: 10 in (255mm)
  • Width: Front 18 in (460mm) / Rear 19 in (480mm)
  • Tire Track: Front 15.5 in (395mm) / Rear 15.75 in (400mm)
  • Wheelbase: 22.5 in (570mm)
  • Ride height: 3 in (76mm)
  • Weight: 21.3lb (with radio)
  • Camber: Adjustable front with shims rear with screw
  • Front caster: Adjustable with shim 22 / 25.5* / 29 degrees (* stock)
  • Toe-in: Adjustable front with tie rod rear with shims 2 / 3* / 4 degree each side (* stock)
  • Aircraft aluminum 6061 T6 monocoque chassis
  • Double wishbone suspension with adjustable roll center F/R
  • Twin plate ventilated disk brake
  • Drive system: HD metal gears with sealed gear box (8.382:1 gear ratio)
  • Diff: Viscous Torque control with 4 pinion gears sealed diff case with silicone oil
  • VVC/HD shock absorbers and fully adjustable coil over springs
  • Wheel type: 3 pcs with high impact nylon material
Engine
  • 2 cycle piston valve gasoline engine
  • Cooling system: Air cooled
  • Displacement: 26cc
  • Fuel: Pre-mixed fuel, 25:1 (Gasoline:High grade 2 cycle engine oil)
  • Starter: Recoil Starter
Radio
  • Transmitter, receiver, throttle servo, receiver battery not included
  • Steering servo: Hi torque, water resistant, metal gears
[ 本帖最后由 JP 于 2007-10-20 11:56 AM 编辑 ]
豆豆樊樊 元老 Fans 发消息
发表于 07-10-20 11:35:18 |显示全部楼层 来自: 中国北京
不知道卖什么价格
自由大帝 超级元老 发消息
发表于 07-10-20 11:36:15 |显示全部楼层 来自: 中国上海
同原来的就只有几个部分5同?仲有无?
bo68674 超级元老 发消息
发表于 07-10-20 11:46:46 |显示全部楼层 来自: 中国广东
已经有人定了!12月底到!
JP 超级元老 发消息
发表于 07-10-20 11:46:52 |显示全部楼层 来自: 中国广东佛山
原帖由 自由大帝 于 2007-10-20 11:36 AM 发表
同原来的就只有几个部分5同?仲有无?
你想有几多唔同 ?
[ 本帖最后由 JP 于 2007-10-20 12:46 PM 编辑 ]
华少 超级元老 发消息
发表于 07-10-20 11:54:32 |显示全部楼层 来自: 中国广东清远
:em07:
JP 超级元老 发消息
发表于 07-10-20 12:02:20 |显示全部楼层 来自: 中国广东佛山
原帖由 豆豆樊樊 于 2007-10-20 11:35 AM 发表
不知道卖什么价格
8xxx
JP 超级元老 发消息
发表于 07-10-20 12:05:09 |显示全部楼层 来自: 中国广东佛山
原帖由 bo68674 于 2007-10-20 11:46 AM 发表
已经有人定了!12月底到!
係咪你 ?
zmx850 论坛元老 发消息
发表于 07-10-20 12:06:40 |显示全部楼层 来自: 中国黑龙江鸡西
漂亮
A+ 终极 Fans 发消息
发表于 07-10-20 12:12:06 |显示全部楼层 来自: 中国广东深圳
带转向舵机哦.感觉不错.喜欢这次配色.跟排气管......那里有啊?
