遥控大猫 超级元老 发消息
发表于 07-8-9 17:25:01 |显示全部楼层 来自: 中国北京
Mugen MRX-4X变身套装发布时间: 2007-8-09 17:24    作者: webmaster    来源: mugenseiki.com
字体:        | 上一篇 下一篇 | 打印
无限精机 Mugen Seiki推出MRX-4R到MRX-4X的变身套装
包括如下
- Rear Upper Arm (2mm Shorter)
- Brake Bracket & Rear Upper Arm Mount for short rear upper arm.
- Rear upright (Adjustable wheel offset)
- Front bulkhead. You can change the tension of the belt (5 different positions).
- Rear bulkhead. You can change the tension of the belt (5 different positions).
- New Eccentric Hub.
- 5mm New Rear Lower Arm Mount
- New Battery Holder (FRP) & Chassis
- New Long rear body Mount Arm & Rear Body Mount Centering Parts
- New Damper End Parts & Rear Damper Case as same as front.
- F/R Damper Stay, Al. Spacer for rear wheel offset, Decal, Set-up sheet are included.
mrx4-x-2
mrx4-x-3
mrx4-x-4
mrx4-x-5
mrx4-x-6
mrx4-x-7
mrx4-x-8
mrx4-x-9
mrx4-x-10
mrx4-x-11
mrx4-x-12
柑蕉桔萝柚 超级元老 发消息
发表于 07-8-9 17:28:50 |显示全部楼层 来自: 中国广东广州
:em07: :em07:
villion 超级元老 发消息
发表于 07-8-9 22:50:27 |显示全部楼层 来自: 中国广东东莞
:em07:
lczhmone02 超级 Fans 发消息
发表于 07-8-10 01:02:04 |显示全部楼层 来自: 中国广东广州
:em04: :em04: :em04: :em04:
