给大家大概介绍一下吧..这控是multiplex的....出来很多年了...名字叫. PROFI.总部再德国..这个样子的一共又3个型号..301, 303, 707. 3字打头的是3通, 7字的是5通..用6节电池..还有..这个控急可以是AM也可以是FM.. General Adjustments Modulation - AM - FM - IPD Trim button sensitivity range 0.5% and 3%, in 0.5% increments Application for Ch 3 - 3-position switch, flasher, prop. channel Trim rocker assignment Mode select 6 different control modes available (7 on 707). Battery threshold, variable from 6.8 - 7.2 V Lap Timer Nominal time (optional sec / 10 sec / min) Throttle & Brake Throttle exponential (301 & 403) Disengaged / Engaged / Lock brake points Idle / Start / Full throttle points Servo reverse Servo format (MPX/UNI) Additional features on the 707 No. of servos 1 throttle/brake servo 1 throttle, 1 brake servo 1 throttle, 2 brake servos Lock point and engage point for 2nd brake servo Steering Exponential (+/- 100%) Servo travel (min, centre, max) Servo reverse Servo format (MPX/UNI) On the 707 you can also adjust: No. of steering servos (1/2) For 2nd servo: travel, reverse and format Memory Management Transfer Model Setups To/From your PC! The PC Interface software is now available for download! Click here to download a .ZIP file with the installation software Switch the current memory Copy the current memory to the selected memory Reset: resets the memory to default values Jason-Jo说的那个和这个象的是Nomido的Mr. Sensor..那是新出的..可以双向交流..但是要加感应头.. |
