大家参考吧 舵机参数 常用舵机数据,小宾提供 型號 速度 扭力 用電/種類/齒種 車種 適合比例 Futaba S 9451 0.10s 8.7Kg/cm 6V/Digital/金屬 EP 1/10 S 9450 0.10s 8.0Kg/cm 6V/Digital/金屬 EP 1/10 S 9550 0.11s 5.8Kg/cm 6V/Digital/金屬 EP 1/10 S 9650 0.11s 4.5Kg/cm 6V/Analog/金屬 EP 1/12, 1/18 S 9405 0.11s 7.2Kg/cm 6V/Analog/金屬 EP 1/10 S 9402 0.10s 8.0Kg/cm 6V/Analog/金屬 EP 1/10 S 3003 0.23s 3.2Kg/cm 6V/Analog/膠 EP 1/10 S 3005 0.19s 4.1Kg/cm 6V/Analog/膠 EP 1/10 S 3010 0.16s 6.5Kg/cm 6V/Analog/膠 EP 1/10 S 3305 0.20s 8.9Kg/cm 6V/Analog/金屬 EP, GP 1/10 S 9350 0.12s 12.0Kg/cm 6V/Digital/金屬 GP 1/8 Hitec HS-5475HB 0.18s 5.5Kg/cm 6V/Digital EP 1/10 HS-5245MG 0.13s 3.5Kg/cm 6V/Digital EP 1/10 HS-5625MG 0.14s 9.4Kg/cm 6V/Digital GP 1/8 HS-5645MG 0.18s 12.1Kg/cm 6V/Digital GP 1/8 HS-5929MG 0.08s 9.2Kg/cm 6V/Digital GP 1/10 HS-5949MG 0.13s 13.0Kg/cm 6V/Digital GP 1/10 HS-475MG 0.18s 5.5Kg/cm 6V/Analog EP 1/10 HS-225MG 0.11s 4.8Kg/cm 6V/Analog EP 1/10 HS-325BB 0.15s 3.7Kg/cm 6V/Analog EP 1/10 HS-645MG 0.20s 9.6Kg/cm 6V/Analog GP 1/8 HS-425BB 0.16s 4.1Kg/cm 6V/Analog EP 1/8 KO Propo PDS-2123FET 0.06s 9.5Kg/cm 7.2V/Digital/金屬 EP 1/10 PDS-2143FET 0.08s 8.0Kg/cm 6V/Digital/金屬 EP 1/10 PDS-2144FET 0.13s 13.0Kg/cm 6V/Digital/金屬 EP, GP 1/10 PDS-2343FET 0.08s 8.0Kg/cm 6V/Digital/金屬 EP 1/10 PDS-2344FET 0.13s 13.0Kg/cm 6V/Digital/金屬 EP, GP 1/10 PDS-947FET 0.09s 2.8Kg/cm 6V/Digital/金屬 EP 1/12, 1/18 PS-2173FET 0.09s 8.0Kg/cm 6V/Analog/金屬 EP 1/10 PS-2174FET 0.13s 12.0Kg/cm 6V/Analog/金屬 EP, GP 1/10 PS-2113FET 0.06s 9.5Kg/cm 7.2V/Analog/金屬 EP 1/10 PS-401 0.16s 3.2kg/cm 6V/Analog/膠 EP 1/10 ps2001 0.09秒,6.5Kg力 ps2004 0.13秒,8kg力 JR Propo DS-559 0.23s 4.8Kg/cm 6V/Digital/金屬 EP 1/10 DS-519 0.23s 3.3Kg/cm 6V/Digital/膠 EP 1/10 DS-8425 0.15s 13Kg/cm 6V/Digital/金屬 GP 1/10 DS-8455 0.08s 7.3Kg/cm 6V/Digital/金屬 EP 1/10 NES-507 0.27s 3.1Kg/cm 6V/Analog/膠 EP 1/10 NES-511 0.26s 3.5Kg/cm 6V/Analog/膠 EP 1/10 Sanwa ERG-VR 0.07s 8.0Kg/cm 6V/Digital/金屬 EP 1/10 ERG-VB 0.10s 13.0Kg/cm 6V/Digital/金屬 EP, GP 1/10 ERG-VX 0.10s 13.0Kg/cm 6V/Digital/金屬 EP, GP 1/10 ERG-VRX 0.07s 8.0Kg/cm 6V/Digital/金屬 EP 1/10 ERG-WRX 0.06s 8.1Kg/cm 6V/Digital/金屬 EP 1/10 SX-101Z 0.18s 3.3Kg/cm 6V/Analog/膠 EP 1/10 SX-112 0.14s 4.0Kg/cm 6V/Analog/膠 EP 1/10 SDX-755 0.11s 5.8Kg/cm 6V/Digital/金屬 EP 1/10 SRM-141HRZ 0.07s 2.3Kg/cm 6V/Digital/金屬 EP 1/12, 1/18 Futaba舵机 型号 特点/用途说明 速度 扭力 s135 小型化模型使用/小型车 0.15秒/60度 1.9kg.cm s135c 电车适用/小型车 0.15秒/60度 1.9kg.cm s136G 薄型/收轮架专用/小型,一般飞机 0.50秒/60度 5.5kg.cm s3001 一般模型适用 0.22秒/60度 3.0kg.cm s3002 高扭力/金属齿/飞机,滑翔机 0.20秒/60度 3.3kg.cm s3003 一般车、飞、机滑翔机、船 0.23\0.19(4.8v,6.0v)/60度 3.2 \4.1 s3050 数位式/薄/吕齿/镍镉电/车用 0.16秒/60度 6.5kg.cm s3101 超小型/小型化模型适用 0.18秒/60度 2.5kg.cm s3102 超小型/金属齿/小型飞行类 0.25秒/60度 3.7kg.cm s3103 超小型/电动飞机适用 0.11秒/60度 1.2kg.cm s3108 超小型 0.12秒/60度 1.2kg.cm s3150 超小型/数位式 0.24秒/60度 3.7kg.cm s3151 一般模型适用/数位式 0.21秒/60度 3.1kg.cm s3302 大型/金属齿/一般飞机、船/引擎车特适 0.19秒/60度 8.0kg.cm s3401 一般车用 0.15秒/60度 3.2kg.cm s3801 高扭力/金属齿/引擎车、飞机/帆船特适 0.26秒/60度 14kg.cm s3802 高扭力/金属齿/帆船专用 0.56秒/60度 11kg.cm s5050 数位式/高扭力/金属齿/引擎车、飞机、船 0.20秒/60度 19kg.cm s5301 大型/高扭力/金属齿/镍镉电/大型模型 0.23秒/60度 21kg.cm s5801 大型/高扭力/金属齿/回旋式/帆船特适 0.50秒/60度 9.8kg.cm s9001 一般模型适用 0.22、0.18秒/60度 3.9、5.2kg.cm s9101 一般飞行类/滑翔机、飞机特适 0.16秒/60度 3.1kg.cm s9102 薄型/超快/飞机副翼专用/飞机特适 0.13秒/60度 3.6kg.cm s9150 薄型4.8v/镍镉电/飞机副翼专用 0.18秒/60度 5.8kg.cm s9151 数位式/高扭力/4.8v/镍镉电/飞机特适 0.19秒/60度 9.5kg.cm s9152 数位式/高扭力/大型飞机特适 0.19秒/60度 20kg.cm s9153 数位式/大型飞机特适 0.15秒/60度 15kg.cm s9154 数位式/薄型/超快/飞机副翼专用 0.14秒/60度 4.6kg.cm s9202 高扭力/铝齿/一般飞机、船/直升机特适 0.22秒/60度 5.0kg.cm s9203 超快/铝齿/镍镉电/飞机直升机特适 0.11秒/60度 5.5kg.cm s9206 高扭力/铝齿/4.8v/镍镉电/飞机直机特适 0.19秒/60度 9.5kg.cm s9250 数位式/高扭力/吕齿/镍镉电/4.8v/飞直机特适 0.19秒/60度 9.5kg.cm s9251 数位式/4.8v/GY601陀螺仪专用 0.07秒/60度 3.7kg.cm s9252 数位式/4.8v/飞机适用/直机特适 0.14秒/60度 6.6kg.cm s9254 数位式/4.8v/GY240、401、502陀螺仪用 0.06秒/60度 4.8kg.cm s9255 数位式/高扭力/铝齿/镍镉电/4.8v/F3C、3D直机特适 0.16秒/60度 9.0kg.cm s9350 数位式/铝齿/镍镉电/吕中段外壳/ 车、船特适 0.12秒/60度 10kg.cm s9351 数位式/铝齿/镍镉电/铝中段外壳1/8引擎车特适 0.13秒/60度 13.8kg.cm s9402 高扭力/铝齿/镍镉电/车、船特适 0.10秒/60度 8.0kg.cm s9405 高扭力/铝齿/镍镉电/车、船特适 0.11秒/60度 7.2kg.cm s9451 数位式/铝齿/镍镉电/车、船特适 0.10秒/60度 8.7kg.cm s9550 数位式/薄型/铝齿/镍镉电/电车专用 0.11秒/60度 6.0kg.cm s9601 小型/小型化飞行类/电车特适 0.16秒/60度 2.4kg.cm s9602 铝齿/电车专用 0.09秒/60度 2.7kg.cm s9650 数位式/1/12电车专用 0.14、0.11/60度 3.6、4.5kg.cm MS-1 超小型/小型飞机用 0.12秒/60度 1.2kg.cm |
