TRAXXAS技术贴视频第二十二期Traxxas 2070和2075舵机如何安装金属舵机齿 视频原创发布者 BY TRAXXAS 翻译者 BY TRAXXAS中国总代理电波模型 因涉及到模型专业术语,如若翻译有误,欢迎指正! ![]() 以英文原档为准,请参考: How to Install Metal Servo Gears in Traxxas 2070 and 2075 Servos How to Install Metal Servo Gears in Traxxas 2070 and 2075 Servos If your model has a 2070 or 2075 steering servo, follow these steps to upgrade to the metal gear set. The 2072X metal gear set is easy to install and instantly increase durability. You will just need a small Philips head and flathead screwdrivers for the installation. First, remove the 4 screws to open the servo case. Remove the existing gears and bearings and thoroughly clean all the debris and grease from the case. Keep the pins, bearings and O-ring from the original setup. Use the small flathead drivers to pry out the bearings. If you want to replace your bearings with new ones, they are available with parts #2072. Install the components according to the diagram using the original pins. Click the link above to download the exploded view diagram. https://traxxas.com/sites/default/files/KC2398-R00_2072X_ServoGearINST-ML-PRESS.pdf https://traxxas.com/sites/default/files/KC2398-R00_2072X_ServoGearINST-ML-PRESS.pdf Make sure to fully seat the nylon insert aligning the tabs on insert with the cutout and the metal gear. Add the nylon insert to the main metal drive gear before adding the bearing and make sure they are both fully seated. Follow this sequence when installing the metal gears and refer to the diagram as needed. Follow this sequence when installing the metal gears and refer to the diagram as needed. Apply a few dabs of the included grease for lubrication. Make sure all the gaskets and O-rings are properly seated before tightening down the screws. Now replace the cover and reinstall the 4 screws in the servo case and your upgraded servo is ready to go. 请支持行货电子设备,电波模型总代理承担非人为损件保修一年,直接换新! 如果您想了解更多关于我们品牌的资讯, 请咨询电波模型淘宝店旺旺客服: http://rcmart.taobao.com/?spm=a1z10.1-c.0.0.U0xSpE 微信扫一扫,可得知最新资讯! ![]() ![]() 或联系我们 QQ :2713236907/270570161 手机:13790546054 王小姐 |
