TRAXXAS技术贴视频第二十一期 何如喷绘Traxxas ProGraphix车壳 视频原创发布者 BY TRAXXAS 翻译者 BY TRAXXAS中国总代理电波模型 因涉及到模型专业术语,如若翻译有误,欢迎指正! ![]() 以英文原档为准,请参考: How to Paint a Traxxas ProGraphix Body | Traxxas Support Today, we will demonstrate how to paint the Traxxas Pro graphic body. Pro graphic bodies are available for many Traxxas model with pre painted graphic for easy painting. We will use an E-Revo body for this demonstration. Note that the body will be painted on the inside and the plastic film should stay on the body until after it’s painted to protect from over spray. A respirator mask is recommended when working with spray paints as well as gloves. Painting should always be done by an adult according to the paint manufacturer’s instructions and an open well-ventilated area. Visit your local hobby shore for a selection of RC body paint. We will use a solid color for the base and then apply a white backing. Use dish soap and water to thoroughly clean the inside of the body. The paint will be applied to the inside and a thoroughly cleaning will help it to adhere to the body. Thoroughly dry the body with a soft cloth or towel. Now, we are ready to start painting. Refer to the directions on the can and apply the paint and short, light, strokes. Applying several light coats will help to avoid dripping and running. Allow the body to dry between coats. When you have full coverage with the base color and the body has dried, apply the backing color. We will use white but silver or black can also be used for different effects. Sliver can give a metallic look to bright base color, while black makes them more opaque. When the paint is fully dry, remove the outer protective peel coat from the body. Now we can apply the decals. Carefully position each decal before applying. If you get an air bubble under a decal, use a pin to carefully puncture the decal and release the air. Additional technique such as using a credit card or hairdryer can also be used to smooth the decals. Now, your pro graphic body is ready to go. 请支持行货电子设备,电波模型总代理承担非人为损件保修一年,直接换新! 如果您想了解更多关于我们品牌的资讯, 请咨询电波模型淘宝店旺旺客服: http://rcmart.taobao.com/?spm=a1z10.1-c.0.0.U0xSpE 微信扫一扫,可得知最新资讯! ![]() ![]() 或联系我们 QQ :2713236907/270570161 手机:13790546054 王小姐 |
