SGP1 TEAM BUG 车手ED 拿下2012 TITC 冠军!!!
13-6-23 22:01| 发布者: rcfans| 查看: 46657| 评论: 13|原作者: rwang
恭喜SGP1 TEAM BUG 车手Ed Clark 赢得2012 TITC 冠军!!! TEAM RW LOTUS 车队 AI 因轮胎问题和助手换胎速度过慢没能进入A10内,不过很高兴有两位SGP1车手进A组。 差一点忘了,TEAM BUG 肉包带病拿下B组冠军!!SGP1 会长A BEN 因该很满意吧!!!
    引用 rave1010hk 12-2-27 00:53
    回复 rwang 的帖子
    ROCKET同学当AI助手时,同样当成去公共蹲厕
    引用 godspeedxi 12-2-27 00:58
    恭喜,恭喜。
    引用 benli46 12-2-27 04:00
    贺电昨天已经发了, 对今年的TITC F1赛事; 还是有点遗憾!
    http://bbs.rcfans.com/forum.php?mod=viewthread&tid=390923&extra=page%3D1&page=49
    引用 刘文锋 12-2-27 08:27
    恭喜恭喜!SGP1车手在TITC大获全胜!!!
    引用 小包 12-2-27 09:29
    SGP1 由此跻身为国际A级赛事~~~
    引用 rave1010hk 12-2-27 12:30
    回复 小包 的帖子
    各位在RCI附出的时间及努力,得到了好成绩的回报!
    引用 E47085 12-2-27 14:42
    这次TITC的F1比赛规则是什么?轮胎有限定吗?
    引用 TryHard 12-2-28 13:34
    I will write in english, hopefully some can then give good translation... :p
    Race was very good. Have to use Ride H1 wheels and tyres, these cause some issue, only lasting for maybe 15minutes with good handling, then the rear tyre fall away. Also using 17.5 with no timing (HW Juststock ESC and motor combination).
    For the A final, had to race for 20minutes, and do a four tyre change between 10 and 12minutes. Also key was we had to change to the S1 tyre compounds, which are softer than the H1, and had not run before.
    I make some change to the car to make it better on these tyres, although this cost me speed on the H1. I also have amazing pitcrew, who do tyre change in around 15seconds... the practise paid off!
    Because of setting change, come into pit's in 7th place, when rejoin the track I am in third. Pass the second place car as he struggles on the soft tyres, and then Andy Moore in first has problems with his battery, causing him to pit two more times.
    This leaves me in the lead with around 3minutes remaining... and then the tyres start to go off, so I decide to back off and just drive it gently to the flag. I cross the line, but still not sure if I had finished or not, but an amazing feeling. Only now is sinking in :)
    Only problem now is I will have to buy a new car, as I'll never use this one again!!
    Regards
    Ed
    引用 爱小车 12-2-29 12:36
    TEAM BUG V5 V5 V5!
    TEAM BUG 将在下一场SGP1赛事期间召开庆功会,为ED,肉包的胜利大吃一顿。
    引用 RANKS 12-2-29 12:54
    HI ED,dont buy another one, we "TEAM BUG" got LOTS of spare cars.......
    引用 rwang 12-2-29 13:05
    Ed, Team RW Lotus "Officially" Welcomes you to join our team for SGP1 Season 2 starting June 2.  We will match ANY offer from any other team!!!
    世界很现实!!! TITC F1 冠军ED是SGP1热门人物!!!
    引用 Z_SHUAI 12-3-1 00:20
    i heard somebody says ... fantastic job! well done ...well done!
    引用 新新小白 12-3-1 16:54
    :em07::em07:
    查看全部评论(13)
