SAVAGE XL Octane汽油大脚车
12-12-12 14:04| 发布者: rcfans| 查看: 12244| 评论: 32
HPI推出Savage XL汽油大脚车,没错!是使用汽油发动机的Savage!名为Savage XL Octane(辛烷)。RTR产品,基于Savage平台研发而成,装备一台15cc汽油引擎,搭载新的冷却系统和排气系统。车架方面,悬挂和车架都进行了强化,以应付汽油引擎强大的动力输出,在车子后部装有防滚架,有效保护引擎等组件。三段变速、大容量油箱、全新全地形轮胎、大扭力金属齿轮舵机都是标准配置。这台汽油版本Savage可能是划时代的遥控车产品,他能否掀起一股中型比例汽油车热潮?请拭目以待!
点击这里->进入RCFans拉力遥控车讨论区参与互动
点击这里->进入RCFans论坛汽油车版块参与互动
SAVAGE XL OCTANE FEATURES LIST:
- All-new 15CC gasoline powered “Octane” engine.
- All-new ducted fan design keeps the engine cooler and more efficient.
- All-new tuned pipe matches perfect to the “Octane” engine for increased torque and overall power.
- All-new composite, triple-disc brake system.
- All-new XL truck body with scale detail and thick polycarbonate for increased toughness.
- All-new extra-strength composite roll cage increases durability.
- All-new extra large fuel tank increases the already amazing runtime.
- All-new designed alloy TVP (Twin Vertical Plate) chassis.
- Full-time shaft drive 4WD system for maximum grip, power and acceleration.
- Proven 2-stage, oversized, oil-filled shocks.
- Sealed all-metal differentials with bulletproof bevel gears help tame the massive torque.
- 2.4GHz radio technology.
- Tough dual-stage air filter.
- Heavy-duty cam-type servo saver steering system.
- All-terrain tires w/ standardized Savage 17mm Hex Hubs.
- Proven Savage XL 3 Speed transmission.
- Proven Savage XL suspension uprights.
- Machined Steel Spur Gear.
- High Torque Metal Gear Steering Servo.
- Rechargeable receiver pack and charger.
- Front and rear bumpers help protect against big hits.
- Extra tough slipper clutch for drivetrain security.
    引用 orange 12-12-17 21:34
    有倒挡没有啊?
    引用 黄小尊 12-12-17 20:56
    4.6的车架不买就是等汽油套件。
    引用 bushwhacker 12-12-17 18:49
    又是必入车,看来我家真的要放不下了....两辆26cc估计要雪藏了
    引用 永远在骚动 12-12-15 21:16
    啊时候 有卖的啊  没5千下不来估计
    引用 liumang6a 12-12-15 18:29
    等测评 等价格呀
    引用 阳阳51651111 12-12-15 16:48
    15  CC  终于来了········期待价格··········
    引用 z961173136 12-12-14 22:32
    学生党伤不起!!!!!!!!!!!!!!
    引用 chinajq 12-12-14 11:19
    什么时候上市?
    引用 城市的主人 12-12-13 18:13
    马环宇: 很值得期待的八车,os发动机,肯定不便宜,估计要7600-8500,左右
    OS发动机?没见啊  哪里说了
    引用 炎焱 12-12-13 16:05
    期待已久了哇。。。。存钱。。。存钱
    引用 马环宇 12-12-13 15:02
    引用 牛奶不纯 12-12-13 14:03
    等评测..等价格..到底是8车还是5车啊?
    引用 GIANO 12-12-13 13:34
    终于出了, 8000左右吧
    引用 devil383x 12-12-13 13:18
    感觉很厉害的样子。
    引用 kidsure 12-12-13 13:06
    关注价格……
    引用 super_弟 12-12-12 22:31
    关注好久了·~~终于出了
    引用 YRD.苍瞳月夜 12-12-12 20:47
    存钱吧。。。别的百搭
    引用 陈威 12-12-12 20:06
    8车汽油引擎,价格不菲啊~~~
    引用 nightsun 12-12-12 19:32
    o o  年初开始关注……
    引用 acejok 12-12-12 19:06
    等的就是她了~~~~持续关注中~~~
    查看全部评论(32)
