Yokomo B-MAX2MR电越
12-11-24 10:32| 发布者: rcfans| 查看: 5469| 评论: 4
Yokomo推出新一代B-MAX2MR两驱电动越野车。新款波箱设计能够提供中置或尾置马达安装设定。其中中置马达设定能够在高抓地力场地,例如地毯路面和人造草皮路面提供更好操控反应和更高弯道速度。尾置马达设定更适合泥地路面,提供更好抓地力。大容量X避振器和新设计的尾珠差等新组件在提高车子性能同时让车子在不同赛道和赛事中有更好适应性。
Features:
  • Two newly designed gear boxes included (for mid-ship 4-gear transmission and rear-motor 3-gear transmission configurations)
  • Newly designed ball diff (Tungsten Carbide diff balls included)
  • Big bore aluminum ‘X’ shocks
  • Hard-anodized shock cap balls and shock end balls
  • Newly designed molded main chassis (mid motor and rear motor)
  • Newly designed aluminum rear suspension mount (toe-in 3°,3.5°,4°)
  • New cab-forward type body shell
  • Steel turnbuckles
  • Double pad slipper clutch
  • Aluminum front brace
  • C-clip universal shafts
  • Full ball bearings
  • Gokuraku off-road wing
  • Pinion gear and wheels included (Tires not included)
    引用 bo68674 12-11-25 09:31
    嗯!好!又多个选择!
    引用 E47085 12-11-24 23:12
    super_弟: 只能用短电。。。。这个设计。。。。。。。。。。。。。。
    倒数第3张图
    引用 super_弟 12-11-24 22:38
    引用 Mini.fans 12-11-24 16:59
    好车。。。。。。。。。。。。。。。。。。。。。。。。。。。。。。
